Home > Computer Hardware > Cables and Adapters > Cable Kits >
  MacPac Power Cable Kit
Our Price: $29.99
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: CBL-002
Description
A "plug and play" power cable kit for your Mac mini! No more cable splicing!!
Carnetix is pleased to announce the only "plug-and-play" power cable solution for the Apple Mac mini and your CarComputer application! The "MacPac" power cable kit connects your mini to the CNX-CA-P1900 or CNX-P2140 DC-DC regulator to provide a quick and simple automotive installation. You are no longer required to cut and splice your Apple AC adapter (brick). The MacPac provides a pre-wired cable between the regulator (P1900 or P2140) and the Mac mini, and includes all power and control signals necessary for full automatic startup and shutdown of the mini. The MacPac is fully compatible with the original Mac mini as well as the new Intel-based mini.
The main white power cable is ~3' from the mac mini power connector. This means your mac mini can be about ~3' from your Carnetix device. Custom cable extensions should be possible to create but will void your warranty.
The power switch portion of this cable kit does not work on mac minis that were made after march of 2009.  A cable for the 2009 mac minis is in the works, but we can not commit to a date until it goes into production.  Until the new switch cable is made, you can still use this cable to power your mac, it will just not be timed to start up and shut down with your engine ignition status.
NOTE: The Power Button cable included in this kit does NOT work with the New Mac Minis (Apple Part No. MB463LL/A). However the main power cable is still compatible. A new Power-button assembly is expected in November.
Features
The MacPac kit includes a Y-cable adapter that is installed between the mini's power button and the motherboard. This allows you continue to use the original Mac mini power button as well as the P1900. The MacPac and Y-cable allow you to easily remove the Mac mini from the car so that you can take the mini inside for software tweaking or updates. When indoors simply use the AC adapter that came with your mini.
The MacPac also provides access to the P1900 or P2140 secondary output, DelayOn amp control, and ground via seperate wires.
http://carnetix.com/installation/IWill_power_cable_instructions.pdf
Related Products...
uSDC Cable Kit
Our Price: $9.99
Add
uSDC Cable Kit
MacPac Power Cable Kit For the NEW Mac Mini
Our Price: $29.99 Pre-Order: Ship Date December 10th 2009
Add
4-Pin P4 - Molex Power Cable
Our Price: $3.99
Add
P4 to Molex4-Pin P4 - Molex Power Cable
Aopen Power Button Cable Kit
Our Price: $14.99
Add
Aopen MiniPC plug-and play Power Button Cable Kit for P1900
Locking SATA II
Our Price: $0.75
Add
Locking SATA II
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Computer Hardware > Cables and Adapters > Power Cables
CarNetix Products (CNX)
Mitch JS USB Audio Selector 4 inputs 1 output - MJS-UAS4S $60.00
