Home > CarNetix Products (CNX) >
  Mac Mini Power Button Cable Kit For Pre March 2009 Models
Our Price: $10.00
Stock Status:In Stock
Product Code: CBL-022
Add A Button:
   Install a manual power switch in a location of your choice.
Description
We have designed a Y-cable and extension cable for the Mac mini that allow you to keep your existing power button intact! The Y-cable goes in between your existing power button cable/connector and the motherboard. The other end of the Y-cable extends out of the Mac mini chassis and connects to the "power button extension cable" which connects to J2 on the P1900. This gives you a way to quickly/easily disconnect your Mac if you want to remove it from your car and take it inside!
This cable does not work on mac minis that were made after march of 2009.
View a PDF of how to install this product here
Browse for more products in the same category as this item:
Cable Ties 8-1/2" Black 100 Pcs $4.99
CMOS Infrared, Night Vision, Waterproof, High Resolution Backup Camera, works with 1" Mounting Hole $39.99
Morex Bundle - Mobile Car Computer System $341.99
Serial port for DSATX (Brainstem TTL to RS232 module) $16.99
Black Momentary Pushbutton Switch 12.5mm $4.99
