Home > Our Products >
  Mac Mini Power Button Cable Kit w/ Momentary Pushbutton for Mac Mini Manufactured March 2009 and Later (Including Unibody Mac Minis)
Our Price: $13.99
Stock Status:In Stock
Product Code: CBL-089
Description Extended Information
We have designed a Y-cable and extension cable for the Mac mini that allow you to keep your existing power button intact! The Y-cable goes in between your existing power button cable/connector and the motherboard. The other end of the Y-cable extends out of the Mac mini chassis and connects to the "power button extension cable" which connects to J2 on the P1900. This gives you a way to quickly/easily disconnect your Mac if you want to remove it from your car and take it inside!  This kit also includes a black momentary pushbutton making your installation even easier.  Please note: the button must be soldered on to the end of the y-cable extender.
Pushbutton Specs:
Dimensions:  12.5mm x 12.5mm
Contact rating:  20mA
Operating force: 120 ± 50gf
Travel: .7mm
Voltage rating: 50VDC
This cable will work with Mac Minis manufactured after March 2009 Including the new unibody Mac Minis.
Please Note:  Installation of these cables on the new unibody Mac Minis requires ADVANCED computer hardware technical skills.  This is NOT recommended for the novice.  Mp3Car does not provide instructions or support on how to do this and cannot be held liable for damage to your Mac Mini while making this modification.
Please see the IMPORTANT installation instructions in the "Extended Information" tab (these instructions are for Mac Minis manufactured between March 2009 and June 2010 and should NOT be used for unibody Mac Minis).
Browse for more products in the same category as this item:
Our Products
Our Products > CarNetix Products (CNX)
