Home > Power > Shutdown Controllers >
  Micro Shutdown Controller
Our Price: $41.99
Stock Status:In Stock
Product Code: PWR-007
Description Technical Specs Extended Information
The uSDC or Micro-Shut-Down-Controller is an electronically controlled automotive power switching device. It is primarily designed for the purpose of starting up or shutting down a personal computer used in a motor vehicle. It interfaces with a computer motherboard’s power switch header that would normally connect to the push-button switch on the front of a personal computer case. The uSDC includes a high current relay that will cut off or apply all power to the power supply of the personal computer to prevent any substantial current draw when the computer is not in use. The uSDC also provides a timing mechanism that is user selectable allowing the computer to remain “on” for an amount of time after the ignition has been turned off. The uSDC allows the user to mount the personal computer in remote locations (such as a trunk) and provides hands off method automating the startup and shutdown sequence while constantly monitoring the environmental conditions.
Note: This is for a PCB board only. User will have to provide adequate casing, blade style automobile connectors, and wiring to properly use this product.
Features
  • Microprocessor Control
  • Voltage Sensing of Battery to prevent over discharge
  • Temperature Sensing (Environmental Protection)
  • Adjustable Low Voltage Threshold
  • Adjustable Power Down Timer Control
  • State indicator feedback LED (Flashes at different rates)
  • 20-Amp Load Switch
  • Fuse Protection
  • Reverse Voltage Protection
  • Load Dump Protection (Over Voltage)
  • Very Low standby power (50 micro-Amps Typical)
  • Startup/Shutdown Motherboard On/Off Pulse
  • Startup on Engine Running
  • Computer “On Sensing” to prevent unknown states
  • User Optional Switch for Instant Off
Browse for more products in the same category as this item:
Power > Startup/Shutdown Controllers
Power
Mac Mini Power Button Cable Kit w/ Momentary Pushbutton For Pre March 2009 Models $13.99
MJS USB IO-1 4 Relay & 4 Input Device $54.95
M4-ATX 250W Intelligent DC-DC PSU $77.95
M3-ATX 125 Watt - Smart Automotive Power Supply $64.99
M2-ATX-HV 140W Intelligent DC-DC PSU $64.99
