Home > Our Products >
  Mini-Box DCDC-USB-200, Intelligent DC-DC converter with USB interface
Alternative Views:
Our Price: $63.95
Stock Status:In Stock
Product Code: PWR-052
Description
DCDC-USB-200, Intelligent buck-boost DC-DC converter with USB interface
DCDC-USB-200 is a high power buck-boost microcontroller DC-DC converter. This unit accepts any input ranging from 6-34V.
Output is 12V regulated or output can be changed with simple jumper settings to 5V, 6V, 9V, 12V, 13.5V, 18V or 24V or via USB in fine increments (0.25V) anywhere from 5-24V.
- Applications:
 powering motherboard with single rail power from any voltage to any voltage, laptops, custom electronics. This module can be used to convert any voltage ranging 6-34V to any output from 5-24V.
The DCDC-USB-200 has 4 models of operation:
Dumb mode: Acts as a regular buck-boost DC-DC converter with wide input (6-34V) and produces a fixed 12V output (or any output from 5-24V)
Automotive mode: Acts as an intelligent PSU, ignition aware, will send ON/OFF pulse to the motherboard to turn ON/OFF. Standby power consumption is well under 1mA.
- UPS mode: The unit will act as an intelligent UPS unit, will shut down at prescribed battery voltages.
Script mode: Unit can be programmed to wake up, sleep, based on pre-programmed scripts.
DCDC-USB-200 software screenshots
Download configuration software here
Additional features of DCDC-USB-200:
- Remote ON/OFF switch capable of switching up to 6A, 8A peak.
- Can control motherboard ON/OFF pins
- Fused input, TVS protected
- USB mini, type B
- All Solid Polymer Capacitors, SVPD series, Sanyo, Japan.
* NOTE: The advanced USB configuration software is intended only for OEM or Advanced Users. Mini-Box.com cannot be held responsible for any damage that might come from the use of this software done to your power supply or other computer components. Application allows advanced setup of DCDC-USB-200 parameters.
Features
- 150watt (180Watt peak)
- Wide range input, 6-34V
- Programmable output 5-24V
- Default output 12V
- High current, up to 15A
- Dual synchrounous buck boost
- Spread Spectrum, out of phase operation
- Applications: power for motherboards with single rail power from any voltage to any voltage, laptops, custom electronics with buck-boost DC-DC.
- Programmable via USB interface
- Sends ON/OFF pulse to motherboard
- 4 modes of operation: DUMB, Automotive, Script or UPS
- 100% Solid Polymer Capacitors, Japan
- manufactured by mini-box.
New! enclosure available:
DCDC-USB-200 Power Box
Browse for more products in the same category as this item:
Our Products
Our Products > Power
Our Products > Power > Pico ATX Power Supplies
