http://www.mp3car.com
Home
My Account
Wishlist
My Cart
0 Items: $0.00
Home
Our Products
Mini-Box Y-PWR, Hot Swap, Load Sharing Controller
Alternative Views:
Our Price:
$29.95
Sale Price:
$19.95
You save $10.00!
Stock Status:In Stock
Product Code:
PWR-046
Description
Y-PWR is a 20A, 30V ideal diode OR. Two power sources such as AC/DC adapters of equal voltage can be used to sum (load sharing) the output power into a single, high power channel. This versatile device can be used as a Hot Swap, Load Sharing / High Availability or Power Patch Controller resulting in a low loss, high efficiency solution for AC/DC and/or battery solution.
Usage example:
Two 12V 90 watt adapters (higher wattage OK) can be 'tied' together in order to produce a 12V 180watt output.
Two 12V 90 watt adapters can be used as a high availability (HA) power source solution. If one power source dies, Y-PWR will automatically switch the the next available source.
The Y-PWR board can be used to perform smooth transition in between AC/DC wall adapter and battery solution. AC/DC input source has to be always higher than battery voltage. NOTE: No battery charging solution is provided.
For more sophisticated operation, each channel can be fully blocked via control pins such as control from a microprocessor.
Multiple Y-PWR controllers can be tied together at the output to integrate larger amounts of power.
precision load sharing solution
hot swap / H.A. solution
2 channels, 30V
20 A output
10A per channel, 15A peak
Low loss 3.9 MOhm / 20A MOSFETS
Each channel is fully blocked
Reduces power dissipation
No Reverse DC current
Multiple Y-PWR devices can be tied together
barrel type and miniFIT JR cables included
Related Products...
25ft VGA Extension Cable
Our Price:
$4.95
Add
Mini-Box picoPSU-150-XT High power, 24 pin mini-IT
Our Price:
$46.95
Add
DCDC USB POWER BOX, For Use with Mini-Box DC-DC co
Our Price:
$4.95
Add
Aopen Power Pac
Our Price:
$24.95
Add
M4-ATX-HV 250W Intelligent DC DC PSU Power Supply
Sale Price: $79.95
Add
Browse for more products in the same category as this item:
Our Products
Our Products
Power
New Products
Our Products
Power
Pico ATX Power Supplies
