Home > Computer Hardware > Computer Cases >
  Morex 5677 Mini-ITX Case w/ 2.5" HDD Mount with PSU
Alternative Views:
Our Price: $85.00
Stock Status:In Stock
Product Code: ENC-022
Description
The Morex 5677 Mini ITX case is compatible with the motherboards we carry in the store.
  • This unit includes a mounting bracket for 2.5" HDD mounting
  • A P4 Cable is not included for motherboards that require this connector.
  • Power Supply is included.
Power Supply Specifications:
  • AC power brick converts wall power to 12v barrel plug on back of computer : 100-240V–1.8A, 50/60Hz
  • PSU input is 12v only.
  • ATX DC Output: +12V/ 5A  60 watts (see some specs and photo  here: http://store.mp3car.com/product_p/pwr-030-0001.htm
Assembled Photo Below is an example of a unit built with the following Parts which are not included for this price:
M2-ATX
USB Super Size Kit
Intel D201GLY2A Little Valley Board
Memory
Other cables
Features
  • Model No.: 5677
  • Color: Black
  • Dimensions(mm): 58.5(H) x 259.5(W) x 186(D)
  • Mainboard Size(mm): Mini-ITX Form Factor ( 170 x 170 )
  • Front Port: N/A
  • System Fan: Yes, 2
  • CD / DVD Device N/A
  • Application:, Vehicle computer, POS, Kiosk, Set Top Box
Browse for more products in the same category as this item:
Computer Hardware
Morex 5677 Mini-ITX Case Without PSU $55.00
Monitor mount stand for Xenarc & Lilliput $15.00
Micro Shutdown Controller $41.99
Mac Mini Power Button Cable Kit w/ Momentary Pushbutton For Pre March 2009 Models $13.99
