Home > Custom Car Computer Systems >
  Morex Bundle - Mobile Car Computer System
Pictures show discontinued D945GCLF2D Motherboard.
Alternative Views:
Our Morex Bundle - Everything you need to get started with 12v or (24v) mobile computing.
Our Price: $341.99
Product Code: CCC-204
Operating System:
   Windows Embeded requires a quantity of at least 25 units.
Memory*:
Keyboards:
   One of the nicest and most compact wireless keyboards with a touchpad we've found!
Prototyping & Systems Integration:
   Includes build & test service, 6 month warranty, installation and configuration of all software, 1 hour phone support for system planning, and 1 hour phone support for technical issues.
Hard Drive*:
WiFi:
Bluetooth:
Centrafuse Software:
   Downloaded and installed by customer.
Description
Ideal for mobile car computing projects on a budget, this is everything you need to get started with 12v or (24v) mobile computing.
Motherboard Intel Motherboard & Processor D510MO (See Bolded Links for more technical specs )
1.6 Ghz Dual Core Atom 510
Intel NM10 Express Chipset
4 USB Ports external
  3USB Ports internal
Rear Connectors and back plate
4- USB Ports
1-VGA
2-PS2/Mouse/Keyboard
1-Gigabit Ethernet
1-Audio Out
1-Audio Line Input
1-Microphone Input
Memory 2 GB of DDR2 Memory (667 MHz) (1 module)
  • option- 4GB DDR2 Memory (2 modules)
Storage
Assembly, Testing, Technical Services
  • option- fast Ship
    • We ship you the parts - you build and test
    • Save 3% off your entire order, including this bundle. Use Coupon Code CCC3%
    • Full manufacturer's warranties apply (see below for details)
    • Standard parts only Mp3car warranty applies
    • How to build yourself video - Building Tips, Tricks (Link)
  • option- Assembled, tested, Ready to go Add 50$
    • 6 month Warranty (2-3 days build and test time)
    • We install your OS & Drivers
Operating System
  • Default option- No OS
  • option- Windows 7 Home Premium Add $114.99
  • option- Windows 7 Pro Add $149.99
  • option- Windows Embedded
    • (25 units or more required)
    • e-mail store@mp3car.com for details.
    • Additional fees apply for embedded image creation or other embedded services
Enclosure or Case Steel Case & Enclosure, Solid, Compact PN#5677
Height - 58.5mm or 2.30 inches
Width - 259.5mm or 10.21 inches
Depth - 186mm or 7.32 inches
Power
Rugged Automotive Power inputs with M2-ATX
Input Power - 6v-24v
Power Consumption
Idle bios screen >24 watts, >2A@12volts
Typical Windows power consumption is 40-60 watts
USB & other accessories will impact the above
Weight
Unpackaged weight is 3.8 lbs / 1.72 Kilograms
Shipping Weight with packing material is ~6.0 lbs / 2.72 kilograms
Warranty
Intel motherboard and Processor combo - 3 years direct from Intel
Seagate ruggedized Hard drive - 5 years (standard hard drive 30 days) direct from seagate
Power Supply - 1 year from mp3car
Mp3car warranty (case, build, test, cables) 6 months, (fast ship option is 30 days)
For all the Warranty details check our policies page
Key Environmental and Shock Specs
Motherboard
Seagate EE25
Ruggedized Hard Drive
Max Operating Temp
55c
85c
Min Operating Temp
0c
-30c
Max input voltage
Min input voltage
MTBF
75,716 hrs at 55c
1 million hrs.
Shock
Tested-See Link
Tested-See Link
Vibration
Tested-See Link
Tested-See Link
Details
Click Here
Click Here
Browse for more products in the same category as this item:
Embedded & Industrial Computers
Serial port for DSATX (Brainstem TTL to RS232 module) $16.99
Black Momentary Pushbutton Switch 12.5mm $4.99
BU-353 Weather-proof GPS Receiver $27.99
DCL11 Automotive Point-Of-Load DC-DC 15W Power Supply $42.99
Automotive/Marine Grade USB Cigarette Port Replacement $24.99
