Home > Custom Car Computer Systems >
  Stage 3 - Nicely Equipped Car Computer Package Deal
  Mp3Car Custom Car Computer (Preassembled Systems)
This complete Car PC System comes with:
1 Jetway  VIA C7 2.0GHz Mini-ITX Motherboard,
1 M2-ATX automotive power supply,
1 VoomPC-2 Enclosure,
1GB DDR2 (PC2-6400) Memory,
1 160GB SATA 2.5" Hard Drive, and
1 CD-RW/DVD Slim Combo Drive.
Our Price: $2,000.00 Please allow up to 3 business days for processing.
Product Code: CCC-121
Operating System:
Centrafuse Software:
   Downloaded and installed by customer.
Description Extended Information
*Please allow up to 3 business days for shipping.
1GB DDR2 (PC2-6400) Memory (usable),
This Car PC System comes pre-assembled and tested. All you need is to install your own Operating System, Car PC Software, and Touch Screen LCD.
Features
 1. Jetway VIA C7 2.0GHz CN700 Mini-ITX Motherboard
- Manufacturer P/N: J7F2WE-2G-OC
- VIA C7 2.0Ghz Processor (20W CPU Power Consumption)
- VIA CN700 + 8237RP
- Front Side Bus: 400/533 MHz
- Graphic Interface: integrated VIA S3 UniChrome Pro AGP graphics with MPEG-2
- 1 x 240-pin DDR2 Module Sockets Support Max 1GB
- Audio: Onboard 6-Channel CODEC Compliant to AC 97'
- On Board 1394a Port
- On Board USB 2.0: 3 x USB headers (support up to 6 x USB 2.0 ports)
- Back Panel I/O: 2 x USB 2.0 ports
- Serial ATA: 2 SATA connectors
- TV-out (PAL / NTSC): VIA VT1622A TV encoder
- Expansion Slot: 1xPCI Slot (PCI 2.2)
- VT6103 10/100 Ethernet
- Dimensions : 170x170mm
- RoHS compliant
Processor
  • VIA C7 2.0GHz Processor  (20W CPU Power Consumption)
  • Chipset
  • VIA CN700 North Bridge
  • VIA VT8237RP South Bridge
  • Expansion Slot
  • Support 1 x PCI Slot (PCI 2.2)
  • On Board 1394a Port (for 627FE/627FWE)
  • Compliant with 1394a OHCI specification Version 1.0
  • Compliant with IEEE 1394a-2000 standard, support 400Mbit/s
  • System Memory
  • 1 x 240-pin DDR2 Module Sockets Support Max 1GB, 1.9V DDR2 400MHz SDRAM
  • Support 8/16/32 /64MB frame buffer
  • Magic Settings
  • Support CPU Front Side Bus step by step setting in BIOS SETUP
  • VGA
  • 16/32/64MB frame buffer using system memory
  • internal AGP 8X performance
  • 128bit 2D/3D VIA S3 Graphics UniChrome Pro Processor
  • 24bit true-color RAMDAC up to 250MHZ pixel
  • UltraDMA 133
  • 2 X UltraDMA 133 IDE Interface (Up to 4 IDE Devices & 133MB/s transfer rate)
  • ATAPI IDE CD-ROM, CD-R,CD-RW and LS-120 Support
  • Onboard LAN
  • IEEE 802.3 10/100 BASE T Standard
  • Boot On LAN function
  • Onboard Audio
  • Software Audio Controller with Onboard 6-Channel CODEC Compliant to AC 97'
  • Serial ATA
  • Support 2 Serial ATA Port provides 150MB/s (Max.)
  • TV-OUT
  • VIA VT 1622A TV encoder
  • Support NTSC/PAL TV system S-Video/AV Output
  • PC'99 Colorful I/O Ports
  • 2xUSB 2.0 Ports, 1xParallel Port, 1xVGA Port, 2xSerial Ports(1xheader,1xConn.)
  • 1xPS/2 Keyboard Port, 1xPS/2 Mouse Port, 1xFloppy Port
  • Line-in/out/MIC Audio Ports
  • add-on board
  • PCMCIA/Compact Flash Reader (Must be Purchased Separately)
  • Form Factor
  • 17 cm x 17 cm
  • 2. ATX Car PC 160W DC-DC Automotive Power Supply
    - NEW160 watts output
    - Ideal car Power supply for operating P4, P4-M, Celeron, AMD systems
    - ATX, 6-24V wide input range
    - Intelligent shutdown controller
    - ON/OFF motherboard control
    - Survives vehicle engine cranks
    - Battery deep discharge prevention
    - High efficiency, 160 watts output
    - "Anti-Thump" Amplifier remote control - 15A automotive fuse (mini-blade)
    3. VoomPC-2 Car PC Black Aluminum Enclosure
    The VoomPC-2 automotive (car, boat, electric cart) enclosure is a small, rugged car PC  enclosure designed to work in harsh enviroments such as dust and high temperatures. Made out of massive 5.5mm extruded aluminum profile, the VoomPC-2 Car PC  encloure was designed to work with any type of mini-ITX motherboard (170x170mm) such as VIA mini-ITX or low power Pentium-M processors, making it the ideal of car PC solution. This car PC enclosure is specifically designed to work with the M1-ATX or M2-ATX car PC automotive power supply series that sold separately.
    The VoomPC-2 Car PC Enclosure can take one Slim CD/DVD drive and a 2.5" HDD drive, it also come with 2 fans for moist/heat removal, easy install under the seat or trunk of the car.
    Dimensions: 210mm (8.3") x 265mm (10") x 66mm (2.2") WxLxH
    Weight: 3.7 kg ( 8 Ibs )
    Enclosure Includes:
    • Front panel USB and audio module
      • RCA ports are not connected from our store.  By design, the RCA wires are run next to the Power Supply which causes induced noise in the audio system.  Because of this, these wires are not connected and the RCA ports are not functional in this build.
    • HDD and CD/DVD drive mounting bracket
    • IDE cable (40 to 44 pin), audio cable, USB cable
    • External power cable
    4. 1GB 240-Pin DDR2 533 Memory
    • Unbuffered 1GB PC6400 533MHz DDR2 Non-ECC CL4 DIMM
    • 60 Day Warranty
    5. 160GB SATA 2.5" Notebook Hard Drive
    • Capacity: 160GB
    • Rotational Speed: 5,400 rpm
    • Cache: 8MB
    • Interface: SATA 150
    • Max. External Transfer Rate: 150MB/s
    • Average Seek Time: 12ms
    • Dimension: 3.94 x 2.75 x 0.42 inch (WxDxH)
    6. CD-RW/DVD Slim Combo Drive
    Type: CD-RW/DVD Slim Combo Bare  Drive
    • Interface: IDE
    • Cache: 2MB
    • Write Speed: 24X CD-R, 24X CD-RW
    • Read Speed: 24X CD-ROM, 8X DVD-ROM
    Related Products...
    Fanless Micro Intel Vehicle Computer
    Our Price: $287.00
    Add
    Power Bundle - Mobile Car Computer System
    Our Price: $594.95 Please allow up to 3 business days for processing.
    Add
    Telematics, Fleet & Public Service Bundle - Mobile
    Our Price: $899.00
    Add
    Telematics, Fleet & Public Service Bundle - Mobile Car Computer System
    Ultimate Micro Intel Vehicle Computer
    Our Price: $749.00
    Add
    Ultimate Micro Intel Vehicle Computer, fleet vehicles, telematics labs, marine, police, fire, ambulance or other ruggedized enviorments.
    Budget Bundle - Mobile Car Computer System
    Sale Price: $415.00
    Add
     Share your knowledge of this product with other customers... Be the first to write a review.
    Browse for more products in the same category as this item:
    BU-353 Weather-proof GPS Receiver $36.00
    Lilliput 7" VGA Touchscreen 619GL-70NP $224.99
