Home > Custom Car Computer Systems >
  Stage 2 - Above the Basics
Mp3Car Custom Car Computer (Preassembled Systems)
This complete Car PC system comes with an Intel dual core Atom motherboard, M2-ATX automotive power supply, VoomPC Enclosure, 2 GB DDR2 DIMM 800MHz, PC2-6400 RAM, and an 160GB SATA 2.5" Hard Drive. This Car PC system comes pre-assembled and tested. All you need is to install your own Operating System, Software, and Touch Screen LCD.  This Car PC system does NOT include a CD-ROM.  If you need a CD-ROM, we suggest the Ultra Slim External Enclosure USB 2.0.
Our Price: $387.99 Discontinued
Stock Status:(Out of Stock)
Product Code: CCC-122
Operating System:
Keyboards:
   One of the nicest and most compact wireless keyboards with a touchpad we've found!
Prototyping & Systems Integration:
   Please allow up to 3 business days.
WiFi:
   Includes antenna & pigtail connector.
Bluetooth:
Centrafuse Software:
   Downloaded and installed by customer.
Description
This complete Car PC system comes with an Intel dual core Atom motherboard (D945GCLF2D), M2-ATX automotive power supply, VoomPC Enclosure,21GB DDR2 DIMM 800MHz, PC2-6400 RAM, and an 160GB SATA 2.5" Hard Drive. This Car PC system comes pre-assembled and tested. All you need is to install your own Operating System, Software, and Touch Screen LCD.
This case does not support an internal optical drive.  To order an external optical drive, buy these two items:
One of these Optical Drives
One Optical Drive Enclosure
Features
  • 1.  Intel D945GCLF2D Mini-ITX Motherboard with Integrated Atom™ Processor
  • • Dual Core Intel® Atom™ Processor 330 integrated (1.6 GHz / 512 KB L2 Cache / 533 System Bus) Chipset
  • • Intel® 945GC Express Chipset with ICH7
    I/O Features
  • • Integrated super I/O LPC bus controller
  • • Two SATA ports (3.0 Gb/s)
  • • One PCI local bus slot
  • USB 2.0
  • • Four back panel ports
  • • Two onboard header providing four additional port support
  • Audio Solution
  • •     Realtek* ALC662 audio codec (5.1 channel HD audio)
    LAN
  • • Onboard 10/100/1000 Ethernet LAN
  • SPI - System BIOS
  • • 4 Mb Flash EEPROM with Intel® Tiano BIOS
  • featuring Plug and Play, IDE drive auto-configure
  • • Advanced configuration and power interface
  • V1.0b, DMI 2.0
  • • Intel® Rapid BIOS Boot Optimized POST for fast access to PC
  • from power-on
    Memory Voltage
  • • 1.8 V
    Wake-up from Network
  • • Wired for Management (WfM) 2.0-compatible
  • • Support for system wake-up using an add-in
  • network interface card with remote wake-up
  • capability
    Expansion Capabilities
  • • One PCI bus add-in card connector
  • Jumpers and Front-Panel Connectors
  • Jumpers
  • • Single configuration jumper design
  • • Jumper access for BIOS configuration mode
  • Front Panel Connectors
  • • Reset, HD LED, Power LEDs, power on/off, aux LED
  • • Two USB 2.0 header
  • • Audio header
  • Mechanical
  • Board Style - Mini-ITX/microATX compatible 6.75” x 6.75” (17.145 cm x 17.145 cm)
  • Desktop Board Power Requirements ATX12V or SFX12V
  • Environment
  • Operating Temperature 0° C to +55° C
  • Storage Temperature -40° C to +70° C
    2. M2-ATX Car PC 160W DC-DC Automotive Power Supply w/ additional P4 Cable
    Smart Car PC Power Supply
    -  ATX, 6-24V wide input range
    - Intelligent shutdown controller
    - ON/OFF motherboard control
    - Survives vehicle engine cranks
    - Battery deep discharge prevention
    - High efficiency, 90 watts output
    - "Anti-Thump" Amplifier remote control
    (mini-blade)
    3. VoomPC Car PC Aluminum Enclosure
    The
  • VoomPC car PC enclosure can take one 2.5" notebook size hard drive,
  • mounted on silicone rubber shock-mounts, easy install under the seat or
  • trunk of the car. The VoomPC enclosure can fit M1-ATX or M2-ATX power
  • supply.
    Dimensions: 210mm (8.3") x 254mm (10") x 56mm (2.2") WxLxH
    Weight: 3.7 kg ( 8 Ibs )
    Case Includes
    • Silicone rubber shock-mount for HDD
      External power cable
      Color: Black or Blue
    4. 160GB  SATA 2.5" Notebook Hard Drive
    • Capacity: 160GB
    • Average Seek Time: 12ms
    • Dimension: 3.94 x 2.75 x 0.42 inch (WxDxH)
    • Weight: 0.22 lb
    • RoHS Compliant
    5.  2 GB DDR2 DIMM 800MHz, PC2-6400 RAM
Browse for more products in the same category as this item:
Mp3Car BoomzBox HD Radio USB Controlled AM/FM Tuner $179.00
Morex 5677 Mini-ITX Case w/ 2.5" HDD Mount with PSU $85.00
Morex 5677 Mini-ITX Case Without PSU $55.00
Monitor mount stand for Xenarc & Lilliput $15.00
