Join our mailing list!
(Your shopping cart is empty)
  Home > Custom Car Computer Systems >
  Stage 5 - Loaded Complete Car Computer Package
  Mp3Car Custom Car Computer (Preassembled Systems)
This loaded Car PC system comes with a Mini PC AOpen MP965-D with a Core 2 DUO Processor, Carnetix P1900 automotive power supply with a AOpen power Pack, 4GB DDR2 Memory, Panasonic Slim Slot load DVD-RW and 250GB SATA 2.5" Hard Drive. This Car PC system comes pre-assembled and tested. All you need is to install your own Operating System, Software, and Touch Screen LCD.
Our Price: $1,252.50 Please allow up to 3 business days for processing.
Product Code: CCC-123
Operating System:
Front End:
   StreetDeck recommends at least a 1.2 Ghz processor and 512MB of Memory.
Description Technical Specs
Features
1. AOpen MP965-D miniPC Duo
Minitaure Size
With a supermini size of just 165 x 165 x 51mm, the Mini PC creates extraordinary desktop space for you to extend unlimited creativity. Using AOpen MiniPC saves you over 40% of space compared to a traditional desktop PC. The saved space can be even larger when fitted with an LCD monitor. The ergonomic effects brought to you by the MiniPC will effectively boost your work efficiency and help maintain a pleasant mood.
Light and Handy - can be easily carried anywhere
Weighing a mere 1.15kg (0.52 lb), the AOpen MiniPC is designed for high mobility. The product fully meets the demands of computer users, who mostly need to carry the computer in a briefcase or handbag from one place to another to continue their work rather than using PCs in the transit process.
AOpen Inc. designs its MiniPC for point-to-point mobility and leaves out monitor, keyboard, and mouse. It further omits the weighty battery so that the MiniPC is lighter than even the lightest notebook PCs available on the market. Despite its light weight, the computer's functions are not compromised at all. Such brand new "portable desktop PC" concept more conforms to consumers' needs.
Superb Performance - Silence, low power consumption, high efficiency
The AOpen MiniPC brings forth a new era for desktop PCs with unrivaled silence, power conservation, and excellent performance by adopting Pentium M/Celeron M processors developed by Intel with mobility technology coupled with a So-DIMM memory slot and Mini-PCI interface. The AOpen MiniPC can easily satisfy the majority of users who mainly work with office applications, enabling them to easily handle office work, entertainment, Internet surfing, CD/DVD burning, etc.
 3. Carnetix PNX-P1900 Dual Output 140 watt 12v DC-DC Regulator
  • 140 Watt Dual Output Regulator
  • Jumper selectable main output of +18/+19/+20V
  • Jumper selectable secondary output of +12V/+13.5V or +5V
  • Survives Engine Cranking under full load over entire temperature range
  • Includes sophisticated Startup/Shutdown Controller
  • Includes sturdy aluminum chassis with variable speed fan suitable for car environment Field upgradable flash microprocessor
  • Low battery monitor prevents drained battery, even during Standby/Sleep
  • "Anti Thump" delayed remote control for audio amplifiers
  • Remote "Pulse Start" from wireless device or car alarm/remote start system
  • Over current protection on both outputs with graceful forced shutdown of main output
  • Powers both your CarPC/Mac AND your screen or USB devices
  • Full, safe support for Windows Standby mode including auto shutdown if PC fails to shutdown
  • Over voltage surge suppression on battery input for protection of harsh automotive environment
  • User replaceable fuse on battery input to protect your car from internal short circuits
4. 4GB DDR2 SODIMM 667 Memory
  • 2 Sticks of 2GB high performance SODIMM memory
  • Unbuffered, Non-ECC, 1.8V Operating Voltage
5. 250GB SATA 2.5" Notebook Hard Drive
  • Capacity: 250GB
  • Rotational Speed: 5,400 rpm
  • Cache: 8MB
  • Interface: SATA 150
  • Max. External Transfer Rate: 150MB/s
  • Average Seek Time: 12ms
  • Dimension: 3.94 x 2.75 x 0.42 inch (WxDxH)
6. SPEC Research RF Wireless Mini Keyboard with Optical Trackball, USB
The SpecResearch 01027 is a high-quality wireless keyboard in a sleek compact form that will free you up from bondage to your desk. This keyboard operates on 2.4 GHz frequency up to 15 meters from the transmitter. This give you the flexibility of use virtually anywhere in the room. The 1027 features 86 normal keys and 13 Function keys for complete control over your entire system.
It is equipped with an optical trackball with 800 dpi resolution, providing 360-degree page navigation. The integrated Multi-media and Internet hot keys provide instant access to your favorite music files, videos and Internet with just a push of a button. This keyboard is available in black with an attractive design that never fails to captivate the eye.
7. 800 Watt Amplifier Installation Kit
- 18 ft. 10GA Red Power Cable
- 4 ft. 10GA Black Ground Cable
- 17 ft. RCA Cable
- 17 ft. Blue Remote Turn-On Wire
- 30 ft. 16GA Speaker Wire
- ATC In-Line Fuse Holder + 30AMP ATC Fuse
- All Necessary Hardware for Installation
RAPTOR DISTRIBUTION BLOCK 1-4GA IN 4-8GA OUT8. Raptor Distribution Block
- (1) 4GA in, (4) 8GA out
- Platinum look finish
- 24K hard gold plated hardware
- Resistant to corrosion
- Durable injection molded, black base and clear acrylic cover
1-4GA IN 4-8GA out
Related Products...
Our Price: $421.57 Please allow up to 3 business days for processing.
Add
Mp3Car Custom Car Computer (5677)
Our Price: $381.33 Please allow up to 3 business days for processing.
Add
Stage 4 - Complete Car Computer Package
Our Price: $1,001.12 Please allow up to 3 business days for processing.
Add
Our Price: $622.42 Please allow up to 3 business days for processing.
Add
MP3Car G4 powered by StreetDeck
Our Price: $2,199.99 Shipping from April 30th
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
MP3Car
3 Churchberry Ct.
Reisterstown, MD 21136
 About Us
 Privacy Policy
 Send Us Feedback
Company Info | Product Index | Category Index | Help | Terms of Use
Copyright © 1999 - 2008 MP3Car.com Inc.. All Rights Reserved.
