When you are ready to take it to the next level, the DSATX has an advanced Serial Port Interface that allows you to connect the DSATX to a serial port. Using an Acroname USB or RS232 translator (Purchased separately) the DSATX can be programmed or monitored. Settings that are programmed over the serial port stay in the memory even after power is completely disconnected from the DSATX.
The DSATX has a simple Character Command interface that put the DSATX into different modes. It also has a simple programming dialog routine to set basic configuration. The DSATX also has an advanced API for configuring a vast range of the DSATX's control routines allowing ultimate flexibility.
Product Includes:
Additional product information:
Please note:
