Home >
  MP3Car G4 powered by StreetDeck - Double Din Car Computer
THE G4 IS FINALLY HERE! Introducing the industry revolutionizing G4! The G4 is a double-DIN sized, all-in-one multi-media computer system that uses a 40GB hard drive, to deliver a new world of entertainment, information, and convenience to all.
The G4 is a double-DIN sized, all-in-one multi-media computer system that uses a 40GB hard disk drive (HDD upgrade to 250GB) , to deliver entertainment, information, and convenience to users. The large-capacity HDD stores the Microsoft MapPoint database, including Internet based lookup for unlimited POI�s. The large 6.5-inch screen shows a high-resolution map with easy-to-recognize icons, and touchscreen operation makes quick access to navigation functions and audio-visual sources. The complete G4 system makes driving safer and more exciting with the following advanced functions:
HDD Music Library
The G4 can use up to 250GB of HDD for a music and video library. You can store 62,500 songs on your 250GB Hard Drive. Infill's automotive hard drive is designed to resist vibration and deliver stable performance to the user.
USBFront and Rear USB Ports
� A front-panel USB input makes it easy to pair up your digital music collection. It will will even charge the battery in your compatible MP3 player or Cell phone while it's connected. Any Supported USB device will
BluetoothBluetooth Phone Control
Get the available Streetdeck Bluetooth Adapter, and use the G4 with compatible Bluetooth cellular phones for easy, safe, and hands-free operation, including talking via the headunit's microphone and your vehicle's speaker system. The system automatically mutes any other audio during incoming or outgoing calls. You can store the phone book, and then access it by the touch screen display. *Optional Bluetooth adapter required
Windows"Factory-Fit"
The G4 is designed for a perfect fit in many vehicles that use a "double-DIN standard". The system fits seamlessly into the dashboard, providing a fit that looks like it just rolled off the lot. The front panel is motorized to provide access to the hidden disc slot. For the optimum viewing angle simply press the screen and hold. Buttons for volume and power are positioned for easy operation.
TouchscreenTouch Screen
Streetdeck�s navigation system is simple and easy. Simply draw a letter on the screen or Just touch large, bright icons on the screen to navigate menus. An easy to read status indicator provides current location information, turn distances. With the use of Acapela Voices and Streetdeck gesturing you will never need to take your eyes off the road.
CD-RWDVDAudio Entertainment System
The G4 is a full-featured audio entertainment system. The built-in DVD/CD player allows you to play either DVD Video, or play CD's with Audio or MP3 files. Listen to AM/FM radio. Your music comes alive with power (44W x 4Ch) and sound performance.
Graphical OBD-II Engine Diagnostics
With the help of the optional OBD-II scanner the G4 can connect directly to your car and diagnose the check engine light and possibly reset the ECU to fix the light. Streetdeck gives you graphical engine diagnostics to give you realtime feedback of whats going on under the hood.
Graphical XM Audio Interface
When combined with the XM package, The G4 features a new user-friendly interface with specific icons for channels and categories. Each of more than 120 XM Radio channels comes with a specific icon. This ensures easy channel identification. Channel categories also come with specific icons, for intuitive selection among corresponding channels. *Optional XM Package
Fully Customizable with Skins and Software Developement Kit
Rear View Camera Capability
Keep an eye on your backside using the optional Rear View Camera. While you're in reverse the rear-view camera can be in full screen.
Download the Owner's Manual
Our Price: $2,199.99
Notes: CurrentyUnavailable
Stock Status: (Out of Stock)
Availability: Pre-Order
Product Code: SDK-014
Memory*:
Hard Drive*:
WiFi:
Accessories
Microphone:
Satellite Radio:
XM Radio [Add $94.99]  (Subscription to XM Satellite Radio required.)
OBD-II:
OBD-II Support (ElmScan 5) [Add $129.95]
Description Technical Specs
THE G4 IS FINALLY HERE! Introducing the industry revolutionizing G4! The G4 is a double-DIN sized, all-in-one multi-media computer system that uses a 40GB-250GB hard drive, to deliver a new world of entertainment, information, and convenience to all.
Features
The much anticipated Mp3Car Infill G4 powered by StreetDeck! For the most up-to-date product information please visit the Infill G4 section of our forums. http://www.mp3car.com/vbulletin/mp3car-infill-g4-double-din-car-computer/
What's in the package:
  • Remote
  • Magnetic GPS antenna and interior mounting plate
  • Mounting Screws
  • Stylus
  • A/V breakout cable
  • USB Extention Cable
  • Harness to connect the unit to your speakers and for all other connections
Additional Parts (NOT Included) You may need for the Install:
  • Car Specific Double DIN Kit / Face Plate
  • Car Specific Wire Harness
  • Car Antenna Converter
Other Notes:
  • The rearview camera input is completely implemented in hardware. It is activated when it detects you are in reverse through the use of reverse geat detection wire and switches the display from the computer to the rearview camera. The computer does not have to be booted for this to work.
  • The screen has 7 different tilt angles. The angle is remembered when starting up and the screen completely closes when it is turned off. To tilt the screen, just press and hold anywhere in StreetDeck where there is not a button. If the top of the screen is pressed, the top tilts in, if the bottom is pressed, the bottom tilts in.
Features supported in StreetDeck:
  • BlueTooth
  • AM/FM Radio
  • GPS
  • DVD playback
  • CD playback
  • OBD-II scanning
  • Internet Radio
  • Navigation
  • You can set the color of the user interface to match your car.
  • Video Play Back
Average Customer Review: Based on 3 Reviews. Write a review.
  0 of 0 people found the following review helpful:
Great Computer Horrible Support/Store March 23, 2009
Reviewer: Rob from Philadelphia PA
I purchased my G4 in 2007 when it was released in the US.  MP3Car seemed like they were willing to work out the bugs and support there product but they instead ignored me after a short time and didnt provide any way for me to reload my G4.  They didnt provide me with restore disks or install disks.  So now I have a computer that if I reload I wont have the slimmed down Windows install, the Navigation Software, the OBDII software, or any of the other software I paid for.
Was this review helpful to you?
Support for third party diagnostic software ? June 17, 2008
Reviewer: Barry Chase from Shelbyville, KY United States
Will the G4 support the use of third party diagnostic software to the likes of http://www.digimoto.com/faq.htm ?
  6 of 15 people found the following review helpful:
PIMP April 13, 2007
Reviewer: Luis Gomez from Humacao, PR United States
OMG this thing is awesome. Finally!
mp3Car.com 7'' Sunlight Readable Touchscreen Monitor $729.99
Lilliput 7" VGA Touchscreen 619GL-70NP $224.99
CarNetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator $99.95
