Home > Monitors and Touchscreens > 10" Touchscreens >
  NEW 2010 Model XENARC 1020TSV - 10.2" VGA LCD Touchscreen Monitor
Our Price: $458.95
Stock Status:In Stock
Product Code: MON-024
Description Technical Specs Extended Information
Please Note:  Mp3Car is now shipping the NEW 2010 model.
Xenarc Technologies Corp. is one of the first LCD manufacturers to introduce a 10.2" LCD screen with VGA input and Touchscreen.  In-Car computing is the next step in computing technology, and we are committed to serving this up and coming technology sector.
This popular product incorporates the innovation of our VGA 10.2" model along with a 5-wire resistive Touch-Screen panel.  Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface.  You can connect several of our touchscreen monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
The brushed, anodized aluminum face plate gives the monitor a futuristic yet elegant look.  The entire enclosure is constructed with aluminum, making the unit both strong and light weight.  The thin profile (only 1.19") makes the monitor very space saving.
This monitor comes included with an instruction manual, an aluminum monitor stand, a U-Shape mount, an AC adaptor, a connection cable, a cigarette lighter car adaptor, and touchscreen drivers for DOS, Windows, Windows Vista, Linux, and Mac OS.
Features
    • For In-Car Computing, PC, Server, GPS, and various VGA Use
    • 5-wire resistive Touch Screen (USB)  *New*
    • Multi-Monitor Touchscreen Support
    • VGA Input (15 pin D-SUB) x 1 & Video Input x 2
    • Audio Input x 3 / Built-in Speakers
    • Picture In Picture / Split Screen
    • Audio Input / Built-in Speaker
    • NTSC / PAL Multi-System
    • 16x9 Aspect Ratio
    • Upgraded High-Brightness LED Backlight *New*
    • Solid Capacitors for increase durability *New*
    • Automatic backlight level adjustment through built-in ambient light
    • sensor *New*
    • Pixelworks High Performance
    • Image and Video Signal
    • Processor *New*
    • AISS - Advanced Image-Scaling and Shaping
    • Last Input memory
    • Last Power setting memory
    • IR Remote Control
    • Auto power-on upon signal detection
    • Automatic display adjustment
    • On Screen Display Control
    • Mirror Image Flip
    • Vertical Image Flip
    • Function to disable front button(s) *New*
    • Function to disable On Screen Text *New*
    • AV2 Auto Switching for backup camera
    • Desktop Stand: 360° Adjustment
    • U-Shape mounting bracket
    • VESA 75mm mounting holes
    • 26-Pin heavy-duty connector
    • Anti Glare Coating
    • Brushed, anodized aluminum face plate
    • Aluminum Casing
    • Supports 10V DC ~ 30V DC
    • *New*
    • "E" Mark Certified for Automotive use
Browse for more products in the same category as this item:
Monitors and Touchscreens > Xenarc
VoomPC-2 CarPC Enclosure $89.95
Volume Control (Rotary Potentiometer) $9.99
