Please Note: Mp3Car is now shipping the NEW 2011 model.
Xenarc Technologies Corp. is one of the first LCD manufacturers to introduce a 10.2" LCD screen with DVI input and Touchscreen.
This monitor utilizes a separate input box which allows a very clean installation. There is only one cable that needs to be connected to the monitor. The external input box takes care of power, a DVI input, a VGA input, 2 Composite video inputs, and 3 audio inputs. And with the optional longer cables, the monitor can sit up to 10 Meters away from the input sources. LVDS signaling is utilized between the monitor and the input box to minimize signal degradation.
Utilizing the newest Pixelworks advanced high performance video processor, the 1026TSA provides outstanding signal processing, de-interlacing, and scaling. This is the same chip that is used in high-end TVs and projectors. Solid Capacitors are used in place of Electrolytic Capacitors though out the unit to further improve the stability and durability especially in extreme temperature conditions.
Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface. You can connect several 1026TSA monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
These monitors come included with an input processing box, instruction manual, a copper monitor stand, a stylus, an AC adaptor, a connection cable, cigarette lighter car adaptor, and touchscreen drivers for DOS, Windows, Windows Vista, Windows 7, Linux, and Mac OS.
The brushed, anodized aluminum face plate gives the monitor a futuristic yet elegant look. The entire enclosure is constructed with aluminum, making the unit both strong and light weight. The thin profile (only 1.19") makes the monitor very space saving.
- Model #: 1026TSA
- Screen Size: Diagonal 10.2" (16:9)
- Physical Resolution: 1024 (H) x 600 (V) WVGA
- Supported Resolution: 640 x 480 ~ 1600 x 1200
- Dot Resolution: 3072 x 600 = 1,152,000 (dots)
- LCD Brightness: 300 cd/m²
- Contrast Ratio: 500:1
- Viewing Angle: 160° Horizontal, 140° Vertical
- Response Time: 10 - 15ms
- Touch Screen Interface: USB port
- Operating Voltage Range: DC 10V ~ 28V
- Power Supply: DC 12V
- Power Consumption: ≤ 20W
- Operating Temperature: -4°F ~ 158°F
- Storage Temperature: -22°F ~ 176°F
- Dimension (in): 10.4W x 7.3H x 1.4D
- Weight (lb): 3
- FCC, CE, E13 Certification
- ROHS Compliant
- 24 Month Warranty
- 30 days No dead Pixel Guarantee
Features
5-Wire Resistive Tochscreen Advantage:- 5-wire resistive analog technology is superior to 4-wire, 8-wire and resistive matrix technologies
- Most durable resistive analog - drift-free operation even when exposed to temperature fluctuation
- Life span of 35,000,000 touches versus 1,000,000 touches from 4-wire resistive
- Increased optical clarity equals higher brightness and a sharper display
- Greater touch point density means better accuracy
- Faster response time and increased speed
- No external electronic correction needed
- For In-Car Computing, PC, Server, GPS, and various VGA Use
- 5-wire resistive Touch Screen (USB)
- Multi-Monitor Touchscreen Support
- VGA Input (15 pin D-SUB) x 1 & Video Input x 2
- Audio Input x 3 / Built-in Speakers
- Picture In Picture / Split Screen
- Audio Input / Built-in Speaker
- NTSC / PAL Multi-System
- 16x9 Aspect Ratio
- Upgraded High-Brightness LED Backlight
- Ultra High Resolution - 1024 x 600 Native
- Solid Capacitors for improved durability
- Automatic backlight level adjustment through built-in ambient light sensor
- Pixelworks High Performance Image and Video Signal Processor
- AISS - Advanced Image-Scaling and Shaping
- Last Input memory
- Last Power setting memory
- IR Remote Control
- Auto power-on upon signal detection
- Automatic display adjustment
- On Screen Display Control
- Mirror Image Flip
- Vertical Image Flip
- Function to disable front button(s)
- Function to disable On Screen Text
- AV2 Auto Switching for backup camera
- Desktop Stand: 360° Adjustment
- U-Shape mounting bracket
- VESA 75mm mounting holes
- 26-Pin heavy-duty connector
- Anti Glare Coating
- Brushed, anodized aluminum face plate
- Aluminum Casing
- Supports 10V DC ~ 28V DC
- "E" Mark Certified for Automotive use
