Home > Our Products >
  New BU-353-S4 Weather-proof USB GPS Receiver
Alternative Views:
Our Price: $32.95
Stock Status:In Stock
Product Code: GPS-004
Description
The NEW BU-353-S4 is a USB GPS receiver that features a highly sensitive, low power consumption chipset in a ultra compact form factor. It is a new improved version of the slower, less accurate lower cost bu-353. The BU-353-S4 is powered by a SiRF Star IV GPS chipset, and will provide you with superior performance in urban canyons, and in dense foliage. With the SiRF CGEE (Client Generated Extended Ephemeris) technology, has the capability of predicting satellite positions for up to 3 days in advance, and will deliver a CGEE-start time of less than 15 seconds under most conditions without any network assistance. The bu-353-S4's MicroPower mode allows the receiver to stay in a hot start-like condition almost continuously while consuming very little power.
The BU-353-S4 is suitable for the following applications:
Automotive navigation
Personal positioning
Fleet management
Mobile phone navigation
Marine navigation
BU-353-S4 Package Contents:
BU-353-S4 USB GPS Receiver
(1) Suction Cup
CD-ROM (User Manual & GPS Info Test Utility)
US Globalsat bu-353 vs bu-353-s4 comparison Chart
General Specifications New BU-353-S4 Original BU-353
GPS Chipset SiRF Star IV SiRF Star III e/LP
Frequency -- L1, 1575.42 MHZ
C/A Code -- 1.023 MHz chip rate
Channels 48 all-in-view tracking 20 all-in-view tracking
Sensitivity -163 dBm -159 dBm
Accuracy -- 5m 2D RMS WARS enabled
10m 2D RMS WARS disabled
Aquisition Rate
Hot start 1 sec., average 8 sec., average
Warm start 35 sec., average 38 sec., average
Cold start 35 sec., average 45 sec., average
Reacquisition 0.1 sec. average 0.1 sec. average
Update rate 1Hz 1Hz
Protocol
GPS Protocol Default: NMEA 0183
Secondary: SiRF binary
Default: NMEA 0183
GPS Output Data SiRF binary >> position, velocity, altitude, status and control NMEA 0183 V3.0 protocol (GGA, GSA, GSV, RMC, VTG, GLL, ZDA) SiRF binary >> position, velocity, altitude, status and control NMEA 0183 V3.0 protocol (GGA, GSA, GSV, RMC, VTG, GLL, ZDA)
GPS transfer rate Software command setting
Default : 4800,n,8,1 for NMEA
Software command setting Default : 4800,n,8,1 for NMEA
Dynamic Condition
Acceleration Limit Less than 4g Less than 4g
Altitude Limit Max 60.000 Feet (18,000 meters) Max 60,000 Feet (18,000 meters)
Velocity Limit Max 515 Meters / sec
(1000 Knots / 151 MPH)
Max 515 Meters/ sec
Jerk Limit 20 m/sec**3 20 m/sec**3
Environmental Specifications
Operating -40- 185F (-4W-- 85C) -40 176F (-40 80C)
Storage -40- 185F (-40- 85C) -40 176F (-4W 80C)
Humidity Up to 95% non-condensing Up to 95% non-condensing
Electrical Characteristics
Voltage 4.5V - 5.5V 4.5V - 6.5V
Current 55mA Maximum 50mA typical
Physical Charateristics
Dimension 2.08" diameter x 0.75"
(53mm dia. x 19.2mm)
USB Cable Length 59" (1,500 mm) 59" (1,500 mm)
Weight 2.2Ounces (62.37g) 2.2 Ounces (62.37g)
Browse for more products in the same category as this item:
Our Products
Our Products > Peripheral Devices > GPS Receivers
Our Products > Peripheral Devices > USB Peripherals
