Home > Our Products > Computer Hardware > Computer Cases >
  New Black Double Din ABS Frame For Lilliput 629 or EBY-701
Our Price: $27.95
Stock Status:In Stock
Product Code: ENC-036-B
Description Extended Information
This second generation frame includes a front mounted mini USB port, a more discrete IR sensor area and an engraved design.This ABS plastic lcd frames makes the LCD installation process easy and secure. Now you can install and remove your lcd component as many times as needed without compromising your screen's integrity. It is intended to be installed behind the OEM radio bezel or any double din dash kit. (Some dash kits may require slight modification to fit the frame).  Easily bolts into many of the aftermarket dash panel kits from Metra and Scosche.
ABS is a strong and rigid plastic, used on many automotive applications such as dash panels, dash boards, radio bezels, handles, etc. Its color and texture helps preserve your car's original look.
Dimensions:
  • Width:  177mm
  • Height:  107mm
  • Depth:  71mm
Material:  ABS Plastic
Package Contents:
  • LCD frame
  • Bracket
  • Mounting Tabs
  • 4 Mounting Screws
  • 6" Flat Ribbon Cable to Extend the IR Component.
  • Printed Installation Instructions
Browse for more products in the same category as this item:
Our Products
