http://www.mp3car.com
Home
My Account
Wishlist
My Cart
0 Items: $0.00
Home
Our Products
Computer Hardware
Computer Cases
New Black Double Din ABS Frame For Lilliput 669GL
Our Price:
$35.99
Stock Status:In Stock
Product Code:
ENC-039-B
Description
Extended Information
This second generation
frame includes a front mounted mini USB port, a more discrete IR sensor area and an engraved design.
This ABS plastic lcd frames makes the LCD installation process easy and secure. Now you can install and remove your lcd component as many times as needed without compromising your screen's integrity. It is intended to be installed behind the OEM radio bezel or any double din dash kit. (Some dash kits may require slight modification to fit the frame).
Easily bolts into many of the aftermarket dash panel kits from Metra and Scosche.
Please note: This frame will not work with the 5-wire Lilliput 669GL-70NP/C/T-5HB monitor.
ABS is a strong and rigid plastic, used on many automotive applications such as dash panels, dash boards, radio bezels, handles, etc. Its color and texture helps preserve your car's original look.
Dimensions:
Width: 177mm
Height: 107mm
Depth: 71mm
Material:
ABS Plastic
Package Contents:
LCD frame
Bracket
Mounting Tabs
4 Mounting Screws
6" Flat Ribbon Cable to Extend the IR Component.
Printed Installation Instructions
Download Installation Instructions here (PDF)
View installation images (HTML)
Related Products...
New Silver Double Din ABS Frame For Lilliput 629 o
Our Price:
$29.99
Add
Morex 5689 Locking Mini-ITX Case With 60W PSU
Our Price:
$84.95
Add
VoomPC-2 CarPC Enclosure
Our Price:
$89.95
Add
DCDC USB POWER BOX, For Use with Mini-Box DC-DC co
Our Price:
$4.95
Add
Morex 5677 Mini-ITX Case
Our Price:
$85.00
Add
Browse for more products in the same category as this item:
Our Products
Computer Hardware
Computer Cases
Our Products
Computer Hardware
Our Products
