Home > Power >
  OPUS 80 Watt DC-DC Power Supply 5V and 12V output
  OPUS 80 watt DC-DC power Supply (5V and 12V Output)DCA5.080.512
Our Price: $116.99
Stock Status: (Out of Stock)
Product Code: PWR-020
Description Technical Specs
OPUS Solutions 80W DC-DC smart power supply is designed specifically to be used in an automotive environment. This product brings a new dimension to your PC’s mobility. When you switch off the Power-ON lead the PC can go into shut down, standby or hibernate modes automatically.
The 80W DC-DC Power supply has a micro-controller that controls and monitors various functions of the power supply operation. It monitors automobile battery voltage to protect against deep discharge. The Power-ON lead is monitored to start the PC when the power is turned on and to implement a safe shutdown procedure. It controls and monitors motherboard signals to provide smooth power-up and power down sequences. In addition, it also responds to shut down, stand-by and hibernate modes.
The power supply can be programmed to shut down the PC after a delay of time. Its outputs are monitored to assure proper PC operation. A green LED indicator in the power supply continually indicates the power system status and health. It is also used for troubleshooting. There are features that are built-in for trouble-free and safe PC operation. The input power is protected against transients, load dumps and double battery during jumpstarts. The PC does not reboot during engine start or cranking. It also uses state-of-the-art technologies and the most advanced techniques to maximize efficiency, performance and reliability. Simply put, there is no other PC power supply like it.
Features
OPUS Solutions, Inc. 80W DC-DC smart power supply is designed specifically for use in an automotive environment.
- 80 Watt output
- Built in auto shutdown
- Delayed shutdown timer
- Wide input voltage range
- On/Off power switch input
- High Efficiency DC-DC Power Supply (extended battery life)
- Remote trigger output
Related Products...
Morex 80 Watt Power Supply
Sale Price: $3.99
Add
M3-ATX 125 Watt - Smart Automotive Power Supply
Our Price: $69.00
Add
AC/DC Power Brick 120 Volt AC to 12V DC 500mA
Our Price: $5.99
Add
CarNetix CNX-PJ-Kit Programming kit
Our Price: $14.99
Add
DSX12VD 140W DC-DC Regulator
Our Price: $84.99
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Power
Power > DC-DC Regulators
7" Touchscreen Replacement for 619 & 629 Lilliput (new version) $40.00
CHRY/PLYM/DODGE/MITS. IMPORTS 1987-94 - INTO CAR 70-1743 $0.99
Xenarc 700 Series extra long Monitor Cable 5 Meters (16.4 feet) $45.00
10pack of 25A Relays $39.99
3-pin Female-Bare Shielded Wire $1.99
AMP. INTEGRATOR PLUG - INTO CAR INTO AMP. HARNESS $0.99
Infrared Distance Sensor $24.99
