OPUS Solutions ITX Mobile-PC Case is designed specifically for Mini-ITX motherboards to be used in an automotive environment. This Product brings a new dimension to your PC’s mobility and size. When you switch off the power ON lead the PC can go into shut down, standby or hibernate modes automatically.
The Mobile-PC Case can accommodate a full Mini-ITX motherboard. The Mobile-PC Case can enjoy the wide selection of hardware and software available for the PC platform. Thus, the Mobile-PC Case is an ideal choice for a fully expandable computer at a reasonable system cost. The system can be upgraded, when required, without losing all the initial investment, unlike laptops. Although tiny, the ITX Mobile-PC Case features unparalleled expandability and system features for a unit it's size.
The Mobile-PC Case's DC-DC Power supply has a micro-controller that controls and monitors various functions of the power supply operation. It monitors automobile battery voltage to protect against deep discharge. It controls and monitors motherboard signals to provide smooth power-up and power down sequences. In addition, it also responds to shut down, stand-by and hibernate modes. The power supply can be programmed to shut down the PC after a delay of up to one hour. The power supply outputs are monitored to assure proper PC operation. A green LED indicator in the power supply continually reports the power system status and health. It is also used for troubleshooting.
