Home > Peripheral Devices >
  OnAir GT HDTV Receiver & DVR for PC
  OnAir GT - ATSC HDTV / QAM receiver / analog TV / video input adapter - USB - External   from OnAir Solution in Input Adapters
Our Price: $179.99 Free Shipping in the US
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: COM-062
Description Technical Specs Extended Information
The OnAir GT is a great HDTV receiver. You can plug it in to an existing cable connection or use the included antenna to watch Over the Air (OTA) broadcasts in analog or digital. It sports a 5th-generation LG Electronics tuner/demodulator which eliminates any multi-path issues and provides the clearest possible picture. What's better than watching TV? Recording it! The included software allows you to watch, record, and pause live TV. You can also configure the included remote to work with outside applications. It is easily portable; take it from your car to your laptop, and when you get home bring it in and plug it into your desktop. These are just a few features that make the AutumnWave OnAir GT the best option for in-car computing!
Features
HDTV (ATSC) / Analog TV (NTSC) / QAM Digital Cable Features
  • Supports HDTV resolutions up to 1920 x 1080 (ATSC)
  • Watch Digital (ATSC), Analog (NTSC) (Even if you are in an area where digital cable broadcasting is unavailable, you can still watch analog TV over-the-air (captured by antenna) and cable TV analog broadcasts.), or Digital Cable (unencrypted QAM) TV (The tuner processes unencrypted high resolution signals in both QAM64 and QAM 256.)
  • The 5th-generation LG Electronics tuner/demodulator offers unsurpassed metro and fringe area reception (The fifth generation VSB chip manufactured by LG has enhanced features that improve reception of digital TV signals even in fringe areas. It supports Terrestrial Digital TV (VSB: Vestigial Side Band) and Digital Cable TV (QAM: Quadrature Amplitude Modulation)) with virtually no multi-path problems.
Playback Features
  • Pause Live TV and Timeshift (Pause TV at your convenience, and press Play when you want to continue) using DVR features (Digital TV)
  • Playback HD stream files (ATSC) (Playback previously recorded material in original quality)
  • Select from six speeds for fast forwarding or rewinding through recorded files
Recording Features
  • Schedule to record (The Scheduled Recording function allows you to record your favorite shows in your absence. It is possible to set up a schedule to record programs on a daily, weekly, or special occasion basis. If the computer is in Standby or Hibernate, the computer will be automatically powered on to run your scheduled item.) up to 80 programs
  • Real-time (The instant record button allows you to save Over-The-Air (OTA) or Cable broadcasts to your hard disk in their native resolution for playback at a later time.) or Scheduled Recording on Digital / Analog TV
  • Still image capture (While watching TV, it is possible to capture and save your favorite scene easily in either BMP or JPEG format.) on Digital and Analog TV (JPEG or BMP format)
  • Time-shift support(Have you ever had to stop watching TV briefly to answer the phone, go to the door, or for other reasons? When enabled, simply click the Pause button, and the Timeshift function will automatically record up to 120 minutes of any TV program you are watching. Return within 120 minutes, and you can click Play to resume watching your show, without missing any program content.) (Digital TV)
  • Record while in time-shifting mode (Have you ever wished you could go back and record a great scene? Now you can! If timeshifting mode is enabled, simply rewind to the beginning of the scene and click the Record button.) (Digital TV)
  • Recording during playback (While playing back a file, clicking Record will save a clip to a separate file.) (allows editing / saving of previously recorded material)
  • D-VHS (You can use your D-VHS device to record Digital programming from the OnAir HDTV Program. You can also playback (and record) clips from your D-VHS device to your PC's hard drive.) HD Stream playback and recording (Windows XP only)
  • Connect your VCR or Camcorder (Simply connect your Camcorder, VCR, or gaming system to the Composite or S-Video input. Click the Record button to save it as an MPEG-2 file on your computer. You can use various 3rd party utilities to then burn this .MPG file to CD or DVD) to record your favorite tapes to PC
  • Connect your favorite gaming console to play and record games on your PC (Connect your favorite video game console to the tuner and use your PC monitor to play your game. Also, record your favorite game sessions so you can play them back for your friends. (Supports up to 720x480))
Audio and Video Features
  • Dolby Digital® 5.1 (Equipped with the most up-to-date HDTV decoding engine, you can experience 5.1 output if your sound card supports it. In addition, with an SPDIF port, you can pass the audio to an external sound system.) Channel support (Digital TV)
  • AC3 / AAC audio decoding
  • Stereo and multiplex sound support
  • SPDIF Output for Digital TV through an AAC compatible sound card (not included)
User-Friendly Features
  • GT easily fits into pocket, backpack or laptop case
  • USB Powered for maximum mobility
  • Remote control (The full featured remote control allows you to control the functions of the TV program from a distance. You can also set it up to control your other PC programs.)
  • Digital Signal Strength Display makes antenna pointing easy
  • Electronic Programming Guide (Electronic Program Guide data is received from Digital TV (OTA) broadcasts. For other sources, this program is compatible with TitanTV's website.) (EPG) (OTA Digital TV)
  • Sleep timer
  • Zoom Navigator (You can zoom in on a certain area of the screen while watching TV. The picture can be zoomed from the default (100%) to a maximum of five times of the current TV view (500%).) to select and enlarge the TV picture
  • Titan TV integration
  • Digital and Analog Closed Caption support
  • Wallpaper TV View (live video or captured images as your desktop background)
Related Products...
Ultrasonic Distance Sensor
Our Price: $34.99
Add
Infrared Distance Sensor
Our Price: $24.99
Add
SPEC Research 01028 USB Wired Optical Trackball
Our Price: $34.99
Add
SPEC Research 01028 USB Wired Optical Trackball Keyboard Mouse
Volume Control (Rotary Potentiometer)
Our Price: $9.99
Add
Logitech diNovo Mini Wireless Keyboard
Our Price: $119.99
Add
Logitech diNovo Mini Wireless Keyboard - Midnight black, Silver - English - US   from Logitech in Keyboards
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Peripheral Devices
Peripheral Devices > Input Devices
Audio, Radio, and Video
