Home > Peripheral Devices >
  PLX Devices Kiwi Wifi OBD-II Tool
Our Price: $139.95 No Longer Available
Stock Status:(Out of Stock)
Product Code: COM-106
Dashcommand Software:
Palmer Performance ScanXL Pro:
Palmer Performance ScanXL Standard:
Description
Kiwi Wifi is a plug and play wireless device measuring only 2.75 x 1.25 x 0.6 inches. Kiwi Wifi comes attached with a 6 ft OBDII cable for easy installation. It also comes included with a power switch built-in to prevent the need for having to constantly disconnect your unit from the OBDII port. It is compatible with 1996 and later vehicles. Connecting to your iPhone / iPod touch is made by 802.11a/b/g connection in adHoc mode. This unit is upgradeable to Kiwi Wifi + iMFD.
Technical Specifications
SSID: PLXDevices
IP: 192.168.0.10
Subnet: 255.255.255.0
Port: 35000
Range: 50 ft (Line of sight)
Antenna: Internal
Power Consumption: 0.7 Watts (With Power Switch)
Wifi Standard: 802.11a/b/g
Operating Temperature: -15 to 100 Deg Celsius
Plastic: Automotive Grade
Physical Dimensions: 2.75 x 1.25 x 0.6 inches
This product is compatible with:
DashCommand for iPhone / iPod Touch by Palmer Performance
(Available on the Apple App Store)
Rev for iPhone / iPod Touch by Dev Toaster
FUZZYCar for iPhone / iPod Touch by FUZZYLuke
Browse for more products in the same category as this item:
Peripheral Devices
Peripheral Devices > OBD-II
Engine Diagnostics and OBD
P4-12V to P4-12V Cable $2.49
OBDLink Multiprotocol OBD-II by ScanTool $89.95
OBDLink Multiprotocol OBD-II by ScanTool WIFI Model $174.95
Sunlight Readable 7'' Touchscreen Monitor Lilliput 669GL-70NP/C/T $649.99
