Home > Computer Hardware > CD/DVD Drives >
  USED - Panasonic Slot Load CW-8124-B DVD-ROM/CD-RW Combo Drive 24x24x24 - USED
Panasonic Slot Load DVD-ROM/CD-RW Combo Drive 24x24x24 CW-8124
PLEASE NOTE: This drive is USED.  It is missing the front face plate.  If you require the front face plate for your installation, you will need to source it elsewhere.  This drive has been tested and is known to work.  This drive is provided 'as is'.
List Price: $68.00
Our Price: $19.99
You save $48.01!
Stock Status:(Out of Stock)
Availability:: Ships in 24 to 48 Hours
Product Code: OPT-006
Accessories:
Description Technical Specs Extended Information
The Panasonic slot load CD Writer DVD Reader is the most popular and cost effective solution for your mini-itx system or custom dash mod. It's slim enclosure and slot loading mechanism will allow you to fit it in most mini-itx systems, or make room for it in your custom dash mold for easy access.
PLEASE NOTE: This drive is USED.  It may be missing the front face plate.  If you require the front face plate for your installation, you may need to source it elsewhere.  This drive has been tested and is known to work.  This drive is provided 'as is'.
Browse for more products in the same category as this item:
Mp3Car Bargain Basement
Mp3Car Bargain Basement > Used
Computer Hardware
P4-12V to P4-12V Cable $2.49
OBDLink Multiprotocol OBD-II by ScanTool $89.95
OBDLink Multiprotocol OBD-II by ScanTool WIFI Model $174.95
Sunlight Readable 7'' Touchscreen Monitor Lilliput 669GL-70NP/C/T $649.99
