| Motherboard |
Intel Motherboard & Processor BLKDG45FC (See Bolded Links for more technical specs )
Intel® Core™2 Duo Processor E7400 (3M Cache, 2.80 GHz, 1066 MHz FSB) Intel G45 Express Chipset Dual-Channel DDR2 800/667 Memory Support 6 High Speed 2.0 USB Ports external 4 High Speed 2.0 USB Ports internal Intel High Definition Audio with 7.1 surround sound
| Rear Connectors and back plate |
6- High Speed 2.0 USB Ports
1-HDMI + DVI Graphics Output
1-Optical Audio Output
1-eSATA back port
1-Audio Out
1-Audio Line Input
1-Microphone Input
| Memory |
2 GB of DDR2 Memory (667 MHz) (1 module) |
| Storage |
| Assembly, Testing, Technical Services |
- option- Assembled, tested, Ready to go!
- 6 month Warranty (2-3 days build and test time)
- We install your OS & Drivers
| Operating System |
- Default option- No OS
- option- Windows Home Add $100
- option- Windows XP Pro Add $169
- option- Windows Embedded
- (25 units or more required)
- e-mail store@mp3car.com for details.
- Additional fees apply for embedded image creation or other embedded services
| Enclosure or Case |
Steel Case & Enclosure, Solid, Compact PN#5677
Height - 58.5mm or 2.30 inches
Width - 259.5mm or 10.21 inches
Depth - 186mm or 7.32 inches |
| Power |
Rugged Automotive Power inputs with M2-ATX
Input Power - 6v-24v
Power Consumption
Idle bios screen >24 watts, >2A@12volts
Typical Windows power consumption is 40-60 watts
USB & other accessories will impact the above |
| Weight |
Unpackaged weight is 4.2 lbs / 1.72 Kilograms
Shipping Weight with packing material is ~6.0 lbs / 2.72 kilograms |
| Warranty |
Intel motherboard and Processor combo - 3 years direct from Intel
Seagate ruggedized Hard drive - 5 years (standard hard drive 30 days) direct from seagate
Power Supply - 1 year from mp3car
Mp3car warranty (case, build, test, cables) 6 months, (fast ship option is 30 days)
For all the Warranty details check our policies page |
| Key Environmental and Shock Specs |
Motherboard |
Seagate EE25
Ruggedized
Hard Drive |
Power Supply |
Max Operating Temp |
55c |
85c |
85c |
Min Operating Temp |
0c |
-30c |
-40 |
Max input voltage |
24v |
Min input voltage |
6v |
MTBF |
75,716 hrs at 55c |
1 million hrs. |
100k hrs 50c |
Shock |
Tested-See Link |
Tested-See Link |
Test on Request |
Vibration |
Tested-See Link |
Tested-See Link |
Test on Request |
Details |
Click Here |
Click Here |
Click Here
