This LCD frame includes the Lilliput 669GL-70NP/C/T model 2010 VGA, DVI, HDMI, 7" LCD VGA Touch Screen. Made of ABS plastic, it's a strong frame that ads a bright screen to your dash. We relocate the IR component in a manner you can use the remote control. Just add your Double din dash kit (AKA Double Din Facia Plates) in front of this frame to preserve your car's dash original look. Easily bolts into many of the aftermarket dash panel kits from Metra and Scosche. Please Note: This item does not include the backup camera auto switch wire.
Features:
- LCD Size: 7" diagonal
- Type: a-Si TFT active matrix
- Native Resolution: 800 x 3(RGB) x 480
- Active Area: 152.4mm (W) x 91.44mm (H)
- Dot Pitch: 0.0635mm(W) x 0.1905mm(H)
- Aspect Ratio: 16:9
- Brightness: 250 CD/Mē
- Contrast Ratio: 500:1
- Light Source: LED
- Surface Treatment: Anti-Glare
- Viewing Angle: 70/70 (left/right) and 50/70 (up/down)
- Video input Signal: VGA, RCA, HDMI, DVI (requires adapter)
- Compatibility: PC, MAC
- Input: 1 VGA, 2 RCA Video, 1 RCA Audio input, 1 HDMI or DVI
- Power: AC to DC power adapter (Input: 100-240V, 50/60Hz, 0.60A Output: 12V, 1200mA)
- Power Consumption: <8 Watts
- Touch Screen: Four Wire Resistive Touch
- Touch Interface: USB
- Speaker: Built in, 1 Watt
- Remote Control: Infrared
- Stand: Detachable, Swivel, Tilt
- Storage Temperature: -20C to 70C
- Operating Temperature: -10C to 60C
Also available with:
Accessories:
- 3'
VGA 9-pin cable extension
- Bracket Support
- Touch pen (on the back of device)
- Drivers CD
- 14PIN SKS cable
- Remote control
- 12V AC/DC power adapter
- User Manual
- 3' HDMI signal cable extension
- 3' DVI line 24+5/DVI-D cable
