Home > Monitors >
  Preassembled Black Double Din LCD Frame with 7" Lilliput 669GL-70NP/C/T-HB-RV HDMI DVI High Brightness
Alternative Views:
Our Price: $299.95
Sale Price: $249.95
You save $50.00!
Stock Status:In Stock
Product Code: MON-125
Adapter:
   Required if using HDMI or DVI input.
Description Extended Information
This LCD frame includes the Lilliput 669GL-70NP/C/T-HB-RV High Brightness model 2010 VGA, DVI, HDMI, 7" LCD VGA Touch Screen. Made of ABS plastic, it's a strong frame that ads a bright screen to your dash. We relocate the IR component in a manner you can use the remote control. Just add your Double din dash kit (AKA Double Din Facia Plates) in front of this frame to preserve your car's dash original look. Easily bolts into many of the aftermarket dash panel kits from Metra and Scosche.
Features:
  • LCD Size: 7" diagonal
  • Backup Camera Auto Switching Wire is Exposed
  • Type: a-Si TFT active matrix
  • Native Resolution: 800 x 3(RGB) x 480
  • Active Area: 152.4mm (W) x 91.44mm (H)
  • Dot Pitch: 0.0635mm(W) x 0.1905mm(H)
  • Aspect Ratio: 16:9
  • Brightness: High Brightness 450 CD/M�
  • Contrast Ratio: 500:1
  • Light Source: LED
  • Surface Treatment: Anti-Glare
  • Viewing Angle: 70/70 (left/right) and 50/70 (up/down)
  • Video input Signal: VGA, RCA, HDMI, DVI (requires adapter)
  • Compatibility: PC, MAC
  • Input: 1 VGA, 2 RCA Video, 1 RCA Audio input, 1 HDMI or DVI
  • Power: AC to DC power adapter (Input: 100-240V, 50/60Hz, 0.60A Output: 12V, 1200mA)
  • Power Consumption: <8 Watts
  • Touch Screen: Four Wire Resistive Touch
  • Touch Interface: USB
  • Speaker: Built in, 1 Watt
  • Remote Control: Infrared
  • Stand: Detachable, Swivel, Tilt
  • Storage Temperature: -20C to 70C
  • Operating Temperature: -10C to 60C
Also available with:
Accessories:
  • 3' VGA 9-pin cable extension
  • Bracket Support
  • Touch pen (on the back of device)
  • Drivers CD
  • 14PIN SKS cable
  • Remote control
  • 12V AC/DC power adapter
  • User Manual
  • 3' HDMI signal cable extension
  • 3' DVI line 24+5/DVI-D cable
Browse for more products in the same category as this item:
Monitors
Monitors and Touchscreens
New Products
Monitors and Touchscreens > Vehicle Specific Parts
Monitors and Touchscreens > In-Dash Touchscreens
Monitors and Touchscreens > Lilliput
Monitors and Touchscreens > 7" Touchscreens
