Home > Monitors >
  Preassembled Black Double Din LCD Frame with 7" mp3Car Sunlight Readable Lilliput 669GL-70NP/C/T
Alternative Views:
Our Price: $699.95
Stock Status:In Stock
Product Code: MON-135
Color
Frame Color*:
   Please allow 5 business days for assembly of Silver and Medium Silver colors.
Adapter:
   Required if using HDMI or DVI input.
Description
Please allow up to 10 business days for assembly and testing.
This LCD frame includes the mp3Car.com 7'' Sunlight Readable Touchscreen Monitor Lilliput 669GL-70NP/C/T. Made of ABS plastic, it's a strong frame that ads a bright screen to your dash. We relocate the IR component in a manner you can use the remote control. Just add your Double din dash kit (AKA Double Din Facia Plates) in front of this frame to preserve your car's dash original look. Easily bolts into many of the aftermarket dash panel kits from Metra and Scosche.
Struggled with hard to read displays long enough or do you own a convertible? If so, this is for you!
This display has been optically enhanced to provide better viewing in the automotive environment including:
  • Tranflective enhancement ensures readability even in direct sunlight
  • Anti-glare technology - provides a wide range of view ability over a wide range of lighting conditions
NEW* This monitor is now based off the Lilliput 669 but has been painstakingly enhanced to ensure maximum viewability in all lighting conditions. Featuring HDMI, DVI, and VGA inputs, this monitor includes all the factory Lilliput accessories.
Anyone who takes this display apart will void the warranty. Mp3car recommends that customer ensure the monitor is working before investing in custom installation services.
Warranty: 60 day warranty provided by Mp3Car.com Inc. Warranty only covers manufacturing defects. It does not cover modifications or physical damages.
Specifications:
  • LCD Size: 7" diagonal
  • Type: a-Si TFT active matrix
  • Native Resolution: 800 x 3(RGB) x 480
  • Active Area: 152.4mm (W) x 91.44mm (H)
  • Dot Pitch: 0.0635mm(W) x 0.1905mm(H)
  • Aspect Ratio: 16:9
  • Contrast Ratio: 500:1
  • Light Source: LED
  • Surface Treatment: Anti-Glare
  • Viewing Angle: 70/70 (left/right) and 50/70 (up/down)
  • Video input Signal: VGA, RCA, HDMI, DVI (requires adapter)
  • Compatibility: PC, MAC
  • Input: 1 VGA, 2 RCA Video, 1 RCA Audio input, 1 HDMI or DVI
  • Power: AC to DC power adapter (Input: 100-240V, 50/60Hz, 0.60A Output: 12V, 1200mA)
  • Power Consumption: <8 Watts
  • Touch Screen: Four Wire Resistive Touch
  • Touch Interface: USB
  • Speaker: Built in, 1 Watt
  • Remote Control: Infrared
  • Stand: Detachable, Swivel, Tilt
  • Storage Temperature: -20C to 70C
  • Operating Temperature: -10C to 60C
Also available with:
Accessories:
  • 3' VGA 9-pin cable extension
  • Bracket Support
  • Touch pen (on the back of device)
  • Drivers CD
  • 14PIN SKS cable
  • Remote control
  • 12V AC/DC power adapter
  • User Manual
  • 3' HDMI signal cable extension
  • 3' DVI line 24+5/DVI-D cable
Browse for more products in the same category as this item:
Monitors
Monitors and Touchscreens
Monitors and Touchscreens > Vehicle Specific Parts
Monitors and Touchscreens > In-Dash Touchscreens
Monitors and Touchscreens > Lilliput
Monitors and Touchscreens > 7" Touchscreens
