Home > New Products >
  Ram Mount Locking Apple iPad Mount With Suction Cup Mount
Our Price: $79.95 No Longer Available
Stock Status:(Out of Stock)
Product Code: MNT-002
Description
The Ram Mount twist lock suction cup mount consists of a 3.25" suction cup locking base, socket system and custom high strength composite locking cradle for the Apple iPad. The mount is designed with a RAM 1" diameter patented rubber ball and socket system that has adjustment points at both ends of the double socket arm; this allowing for almost infinite adjustment and perfect viewing angles. Simply attach the suction cup base to the windshield of your vehicle for an easy and safe way to view your handheld device in your vehicle. High quality materials ensure your electronic device is safe, secure, and within easy reach. RAM’s patented design also dampens shock and vibration helping to extend the life of your mobile device.
This mount is designed to hold the following devices:
Apple iPad Wi-Fi 16GB, 32GB and 64GB
Apple iPad Wi-Fi + 3G 16GB, 32GB and 64GB
Locking Cradle Features:
1. Easy access to electronic ports
2. Dial combination lock
3. (4 qty) mounting points with pre-drilled holes, including the universal AMPS hole pattern.
Material:
High Strength Composite & Powder Coated Marine Grade Aluminum
Ball Size:
1" Rubber Ball "B" Size
Browse for more products in the same category as this item:
New Products
Our Products > Tablet Vehicle Mounts
Our Products
