Home > New Products >
  Ram Mount Pod I No Drill Vehicle Rod With Locking Apple iPad Cradle Holder Mount
Our Price: $84.95 No Longer Available
Stock Status:(Out of Stock)
Product Code: MNT-005
Description
RAM POD I, universal No-Drill™ vehicle mount with locking cradle, for the Apple iPad. The base mounts to your seat rail without any drilling necessary. Connected to the base is a 18" rigid flexible rod that can be bent to position your device to it's optimum viewing location. The RAM POD I will hold everything you need safely and securely.
This mount is designed to hold the following devices:
Apple iPad Wi-Fi 16GB, 32GB and 64GB
Apple iPad Wi-Fi + 3G 16GB, 32GB and 64GB
Locking Cradle Features:
1. Easy access to electronic ports
2. Dial combination lock
3. (4 qty) mounting points with pre-drilled holes, including the universal AMPS hole pattern.
Material:
High Strength Composite & Powder Coated Marine Grade Aluminum
Ball Size:
1" Rubber Ball "B" Size
Browse for more products in the same category as this item:
New Products
Our Products > Tablet Vehicle Mounts
Our Products
