Please note that is only an antenna, it does not contain any receiver or transmitter hardware. For example, if you wanted this to work with a GPS receiver you would need a GPS module that supports an external antenna. Cellular/PCS can be connected to a G3 or EVDO wireless card -- or a mobile phone. The Wifi portion of the antenna can be used with any WiFi wireless card that supports an external antenna. Additional adapters may be required to connect from the wireless modules to the FME female antenna connectors.Manufacturer's Description: Roof mount antenna for GPS, Multi band (AMPS, GSM 900, GSM 1800, UMTS) and Wireless LAN for car navigation, traffic guidance systems, fleet management.
Mechanical construction details: Dimensions (W x H x D) 81 x 45 x 42 mm (without rod) Weight 255 g Housing material PA6 Rod section 1 Rod length 50 mm Rod inclination 74° Installation Environmental conditions Temperature range -40° - +80° C Protection class IP66 (acc. IEC 60529)
GPS Frequency range 1.57542 GHz +-1.023 MHz, (L1-band) Return loss > 12 dB Impendance 50 Ohm Current consumption max. 30 mA Gain typ. 2 dBic Amplification 24 dB +-4 dB Noise figure < 2.5 dB Voltage supply 3 - 5 VDC (remote fed) Cable type RG 174 Cable length 3000 mm Connector FME female
CELLULAR Frequency range AMPS: 824 - 894 MHz GSM 900: 880 - 960 MHz GSM 1800: 1710 - 1880 MHz GSM 1900: 1850 - 1990 MHz UMTS: 1900- 2170 MHz Impedance 50 Ohm Load capacity max. 8 W pulsed acc. GSM standard Return loss > 12 dB Decoupling > 40 dB Rod wave 1/4 Rod gain 0 dB Cable type RG 174 Cable length 3000 mm Connector FME female
WLAN
