Home > Peripheral Devices > GPS Receivers >
  Rooftop GPS/Cellular/PCS/WiFi antenna
  Roof top GPS/Cellular/PCS/WiFi antenna
Our Price: $74.99
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: COM-008
Description Technical Specs Extended Information
Mp3Car Description: Free you roof of multiple antennas! Ideal for low profile installs with high wireless performance. Rather than have up to four separate antennas on your roof, this allows the consolidation of all those antennas into one unit. This antenna allows for optimal positioning on the roof which can increase wireless performance.
Please note that is only an antenna, it does not contain any receiver or transmitter hardware. For example, if you wanted this to work with a GPS receiver you would need a GPS module that supports an external antenna. Cellular/PCS can be connected to a G3 or EVDO wireless card -- or a mobile phone. The Wifi portion of the antenna can be used with any WiFi wireless card that supports an external antenna. Additional adapters may be required to connect from the wireless modules to the FME female antenna connectors.
Manufacturer's Description: Roof mount antenna for GPS, Multi band (AMPS, GSM 900, GSM 1800, UMTS) and Wireless LAN for car navigation, traffic guidance systems, fleet management.
Related Products...
BU-353 Weather-proof GPS Receiver
Our Price: $37.55
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Peripheral Devices
