This monitor works well for Camera or Video Camera
applications as extended monitor. It can also be used to connect a Car-PC,
Computer, DVD player etc. through the HDMI or VGA port. It can be powered with
the Sony F970 battery.
- TMR Technology, Sunlight readable, Integrated
TCON Interface, 24bit RGB TTL Signal.
- Industry Grade Samsung LED Panel (working temp from -20°C to 60°C)
- Supports HDMI HD input. 800x480 native
resolution, up to 1080p (1920x1080). Integrated speaker.
- Transparent OSD menu will not block
image during settings. Also no OSD title showing when switching channel,
perfect for Car Reverse Camera System.
- Switchable to battery power with the
Sony F970 battery, 10 hours of usage.
Standard VESA Mounting (75mm) and Camera Hot-Shoe
Mounting are provided.
- Great "Black" and Contrast
- Back-light/ GAMMA dual adjustable
- Color Temp adjustable
- Sharpness/ Contrast adjustable
- Wide-Range Voltage Support (7V - 20V,
2A)
- Shortcut key for black/color switching
- Shortcut key for 16:9 / 4:3 switching
Supports Auto-On. When the monitor receives signal
from trigger, it will auto turn on and switch to AV-1 channel. Works well for a
car reverse camera system.
Includes:
- 1x 7" LED LCD Monitor, integrated
USB Resistive Touch Screen
(2 Composite + 1 VGA input + 1 HDMI input)
- 12V AC-DC Adapter
- 1x HDMI to HDMI-mini Cable (short)
- 1x HDMI to HDMI Cable (short)
- 1x 3-to-1 AV cable
- 1x Hot-Shoe Adapter
- 1x Sony F970 Battery Adapter (battery
not included)
Technical Specifications:
- Brand: Samsung
- Model# LMS700KF07-004
- Size: 7.0 inch
- Resolution: 800 x 480
- View Angle: L70° R70° U50° D60
- Display mode: TMR
- Backlight: 24 LED
- Interface: 24bit RGB
- Brightness(cd/m²): 300 (w/TSP)
- Contrast Ratio: 400:1
- Connector: 40 pins FPC Digital
- Response Time: 5 - 28 ms
- LED Current: 15 - 25 mA
- Power Consumption: 1.2 - 2.0 W
- Active Area (mm): 152.40 x 91.40
