Home > New Products >
  ScanGauge II 3-in-one Automotive Computer by Scantool
Alternative Views:
Our Price: $159.95 No Longer Available
Stock Status:(Out of Stock)
Product Code: COM-142
Description
The integrated Trip Computer provides realtime feedback while simultaneously tracking three sets of trip data. The Digital Gauges give you realtime data for your vehicle and the built-in Scan Tool allows you to read trouble codes and diagnose potentially expensive problems before they get out of hand.
Visit msnbc.com for Breaking News, World News, and News about the Economy
Connects In Seconds
The cable is detachable at the ScanGauge II and can be connected on the back or side of the unit. Once connected to your vehicles OBDII port, the ScanGaugeII automatically negotiates communications with your cars computer - It's that easy!
Fits Almost Anywhere
The compact size of the ScanGaugeII allows you to mount just about anywhere. It's so small, you can even slip it into your pocket and take it with you.
The dimensions of the ScanGaugeII are 4.8" wide by 1.5" high by 1.0" deep. The cord from the diagnostic connector to the control/display is 6' long and about 0.2" in diameter.
Built-In Scan Tool
The ScanGauge II can check for Diagnostic Trouble Codes (DTCs) and if found, can display how many there are and the Trouble Codes themselves. Using the internet or repair manuals, these can be translated to the failed component and repairs can be made.
Data captured when the Trouble Code was set can be recalled to help troubleshoot the problems (was the temperature hot or cold, speed high or low, etc). The ScanGauge II can be used to clear the trouble codes and data which will turn off the warning (Check Engine, Service Engine soon, etc) lamp.
Some states now require that vehicle self tests have been completed since the codes were last cleared, before running emissions checks. The ScanGauge reports this "Readiness".
  • Reads Trouble Codes
  • Reads Conditions that set the Trouble Code
  • Clears Trouble Codes
  • Turns off "Check Engine" light
  • Tells you when vehicle is "Ready" to pass OBDII testing
  • Make and store up to 10 rewritable special codes to send to the vehicle computer
  • Ships with the latest version of X-Gauge
Digital Gauges
The ScanGauge II can display up to 4 of 12 possible gauges at one time. The units of measure can be changed and the rate of update can be increased or decreased.
  • Fuel Economy
  • Fuel Rate
  • Battery Voltage
  • Coolant Temperature
  • Intake Air Temperature
  • Engine Speed (RPM)
  • Vehicle speed (MPH and KM/H)
  • Manifold Pressure (not available on some vehicles)
  • Engine Load
  • Throttle Position
  • Ignition Timing
  • Open/Closed Loop
Trip Computers
The CURRENT trip is restarted after the engine has been off for more than 3 minutes. The TODAY trip is restarted after the vehicle has not moved for 9 hours. The data from TODAY is moved to PREVIOUS DAY when it is restarted. This way, you don't have to reset the trip computers when you start a trip. There is also a TANK Trip which you reset when you fill up the tank. It can provide you with "to empty" data as well as other useful information. The information is available anytime during the trip. The CURRENT trip can be reset. This is useful for making fuel economy measurements at a steady speed.
The GAUGE mode can display instantaneous fuel economy, but small variations in throttle, terrain or even wind will cause this to wander around some. The CURRENT trip computer and its RESET capability can smooth this out over a longer distance. A demonstration of how to do this can be chosen below.
The TRIP modes in the ScanGauge II can be used to save gas. Improved driving habits can improve fuel economy by up to 30% according to a US Government source. The ScanGauge II lets you try different driving techniques and routes and gives quick feedback on how they affect fuel use.
  • Maximum Speed
  • Average Speed
  • Maximum Coolant Temperature
  • Maximum RPM
  • Driving Time
  • Driving Distance
  • Fuel Used
  • Trip Fuel Economy
  • Distance to Empty
  • Time to Empty
  • Fuel to Empty
Contents
  • ScanGaugeII unit
  • 1 ScanGaugeII cable, (6 ft)
  • ScanGaugeII manual
  • 2 velcro strips
When you buy scan tools from ScanTool.net, you get:
  • Risk-free, hassle-free 30-day unconditional money back guarantee.
  • Best warranty in the industry. Your ScanGaugeII is covered by a 1-year limited warranty. If it fails, we will promptly repair or replace it free of charge.
  • Compatibility with the widest range of vehicles.
Browse for more products in the same category as this item:
New Products
Our Products > Engine Diagnostics and OBD-II
Our Products
