- Standard double din
mounting size
- "Black Box" (silver in color)
- Compact user friendly design
for easy access and maintenance
- Fits standard Nano-ITX form
factor boards
- Pico-ITX & SBC Boards installable with standoffs
- Fully ventilated
with 40mm cooling fan
- Internal
amplifier can be installed inside (optional)
- LCD frame can
hold 7" Lilliput®
lcd screens
- Some
double din dash kits may require 3-4 mm trimming to fit the LCD frame
Black Box-N brings a robust solution for the Carputer enthusiasts willing to
install their double din in dash infotainment system. Built of high
resistance ABS plastic, this fully ventilated rugged enclosure provides
secure support to the small from factor boards as well as the 7" LCD touch
screens from Lilliput Electronics®
(LED version).
Fully customizable: The ABS plastic material makes it easy to add custom
devices by drilling holes and adding adhesive standoffs on the desired
positions. Its removable cut out window exposes fixed board ports
Recommended hardware
Motherboard - Via Epia NX15000G
- Via Epia N1200EG
- Portwell Nano-8044 series board
- Contron SBC (Single Board Computer)
- Via Pico-ITX boards
Power Supply Memory LCD Screen Storage
The Benefits of ABS
ABS possesses outstanding impact strength
and high mechanical strength, which makes it so suitable for tough consumer
products. Additionally, ABS has good dimensional stability and
electrical insulating properties. ABS plastic is versatile, lightweight,
flexible, moisture and corrosion resistant, durable, strong, heat resistant
and relatively inexpensive. It is also fully recyclable.
Material |
ABS plastic |
Box dimensions: |
177mm(W)
100mm(H)
177mm (D) |
Frame dimensions: |
177mm(W)x107mm(H) |
Weight: |
1.25 Lb |
Operation
temperature: |
-20o C to 70o C |
Power: |
Needs 12V DC psu |
Display: |
Can be used with 7"
Lilliput EBY701 or 629GL |
Form factor: |
Nano-ITX or smaller |
Power supply: |
M3 ATX PSU recommended |
Audio: |
2x 3.5mm jack to board audio header
adapter
1x 2.5mm optional |
Cooling fan: |
40x40x10mm ball bearing
Silent 5,000 rpm
12VDC, 3 pin connector |
Noise Level: |
<21 dBA |
Power wiring: |
6 contact 20WGA color coded power
harness |
Audio wiring: |
8 contact 20WGA color coded speakers
harness optional |
Other: |
Molex to 5V DC
adapter |
Package Contents|
QTY |
ITEM |
1 |
Black
Box |
1 |
40mm
cooling fan with 3 pin connector |
1 |
"H"
bracket to support LCD controller board |
1 |
Molex
to 5V power jack adapter |
1 |
6 pin
power harness with 2.5mm power plug |
2 |
3.5mm
Audio jack with wires and crimp connectors (assembled) |
1 |
2.5mm
Audio jack with wires and crimp connectors (not assembled) |
1 |
14
pin 2.0 pitch header socket for audio port |
16 |
4x1/4
pan head screws |
4 |
2x1/4
pan head screws to support controller board |
6 |
4x1/4
truss head screws |
4 |
4-40
X 3/16 machine screws for hard drive |
1 |
6"
Flat ribbon cable to extend IR remote sensor | Additional LinksAssembly InstructionsAudio Port Schematics Lilliput VGA Wiring SchematicsFilter Noise Choke DiagramsAmplifier Installation Guide
