Join our mailing list!
(Your shopping cart is empty)
  Home > Custom Car Computer Systems >
  Stage 4 - Complete Car Computer Package
This complete Car PC System comes with a Xenarc 7" VGA Touchscreen 705TSV, Jetway  VIA C7 2.0GHz Mini-ITX Motherboard, M2-ATX automotive power supply, VoomPC-2 Enclosure, 1GB DDR2 Memory, 120GB SATA 2.5" Hard Drive, SPEC Research USB Wired Keyboard/Mouse, Amplifier Installation Kit, and CD-RW/DVD Slim Combo Drive. This Car PC System comes pre-assembled and tested. All you need is to install your own Operating System and Car PC Software.
Our Price: $1,001.12 Please allow up to 3 business days for processing.
Product Code: CCC-126
Operating System:
Front End:
   StreetDeck recommends at least a 1.2 Ghz processor and 512MB of Memory.
Description
Features
1. Xenarc 7" VGA Touchscreen 705TSV
This popular product incorporates a 4-wire resistive Touch-Screen panel. Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface. You can connect several 705TSV monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
This monitor comes included with an instruction manual, a copper monitor stand, a stylus, an AC adapter, a connection cable, a cigarette lighter car adapter, and touchscreen drivers for DOS, Windows, Windows Vista, Linux, and Mac OS.
Key Features:
  • Screen Size:  Diagonal 7"  (16:9)
  • Physical Resolution: 800 (H)  x 480 (V) WVGA
  • Supported Resolution:  640 x 480 ~ 1024 x 768
  • Dot Resolution: 2400 x 480 = 1,152,000 (dots)
  • LCD Brightness: 450 cd/m²
  • Contrast Ratio: 400:1
  • Viewing Angle: 140° Horizontal, 120° Vertical
  • Touch Screen Interface: USB port
  • Operating Voltage Range: DC 11V ~ 24V
  • Power Supply: DC 12V
  • Power Consumption:  <5W
  • Operating Temperature:  23°F ~ 158°F
  • Storage Temperature:  -22°F ~ 185°F
  • Dimension (in):  7.63W x 4.88H x 1.14D
  • Weight (lb):  1.15
  • FCC, CE, E13 Certification
  • ROHS Compliant
  • 18 Month Warranty
 2. Jetway VIA C7 2.0GHz CN700 Mini-ITX Motherboard
- Manufacturer P/N: J7F2WE-2G-OC
- VIA C7 2.0Ghz Processor (20W CPU Power Consumption)
- VIA CN700 + 8237RP
- Front Side Bus: 400/533 MHz
- Graphic Interface: integrated VIA S3 UniChrome Pro AGP graphics with MPEG-2
- 1 x 240-pin DDR2 Module Sockets Support Max 1GB
- Audio: Onboard 6-Channel CODEC Compliant to AC 97'
- On Board 1394a Port
- On Board USB 2.0: 3 x USB headers (support up to 6 x USB 2.0 ports)
- Back Panel I/O: 2 x USB 2.0 ports
- Serial ATA: 2 SATA connectors
- TV-out (PAL / NTSC): VIA VT1622A TV encoder
- Expansion Slot: 1xPCI Slot (PCI 2.2)
- VT6103 10/100 Ethernet
- Dimensions : 170x170mm
- RoHS compliant
Processor
  • VIA C7 2.0GHz Processor  (20W CPU Power Consumption)
  • Chipset
  • VIA CN700 North Bridge
  • VIA VT8237RP South Bridge
  • Expansion Slot
  • Support 1 x PCI Slot (PCI 2.2)
  • On Board 1394a Port (for 627FE/627FWE)
  • Compliant with 1394a OHCI specification Version 1.0
  • Compliant with IEEE 1394a-2000 standard, support 400Mbit/s
  • System Memory
  • 1 x 240-pin DDR2 Module Sockets Support Max 1GB, 1.9V DDR2 400MHz SDRAM
  • Support 8/16/32 /64MB frame buffer
  • Magic Settings
  • Support CPU Front Side Bus step by step setting in BIOS SETUP
  • VGA
  • 16/32/64MB frame buffer using system memory
  • internal AGP 8X performance
  • 128bit 2D/3D VIA S3 Graphics UniChrome Pro Processor
  • 24bit true-color RAMDAC up to 250MHZ pixel
  • UltraDMA 133
  • 2 X UltraDMA 133 IDE Interface (Up to 4 IDE Devices & 133MB/s transfer rate)
  • ATAPI IDE CD-ROM, CD-R,CD-RW and LS-120 Support
  • Onboard LAN
  • IEEE 802.3 10/100 BASE T Standard
  • Boot On LAN function
  • Onboard Audio
  • Software Audio Controller with Onboard 6-Channel CODEC Compliant to AC 97'
  • Serial ATA
  • Support 2 Serial ATA Port provides 150MB/s (Max.)
  • TV-OUT
  • VIA VT 1622A TV encoder
  • Support NTSC/PAL TV system S-Video/AV Output
  • PC'99 Colorful I/O Ports
  • 2xUSB 2.0 Ports, 1xParallel Port, 1xVGA Port, 2xSerial Ports(1xheader,1xConn.)
  • 1xPS/2 Keyboard Port, 1xPS/2 Mouse Port, 1xFloppy Port
  • Line-in/out/MIC Audio Ports
  • add-on board
  • PCMCIA /Compact Flash Reader
  • Form Factor
  • 17 cm x 17 cm
  • 3. M2-ATX Car PC 160W DC-DC Automotive Power Supply
    - 160 watts output
    - Ideal car Power supply for operating P4, P4-M, Celeron, AMD systems
    - ATX, 6-24V wide input range
    - Intelligent shutdown controller
    - ON/OFF motherboard control
    - Survives vehicle engine cranks
    - Battery deep discharge prevention
    - High efficiency, 160 watts output
    - "Anti-Thump" Amplifier remote control - 15A automotive fuse (mini-blade)
    4. VoomPC-2 Car PC Black Aluminum Enclosure
    The VoomPC-2 automotive (car, boat, electric cart) enclosure is a small, rugged car PC  enclosure designed to work in harsh enviroments such as dust and high temperatures. Made out of massive 5.5mm extruded aluminum profile, the VoomPC-2 Car PC  encloure was designed to work with any type of mini-ITX motherboard (170x170mm) such as VIA mini-ITX or low power Pentium-M processors, making it the ideal of car PC solution.
    The VoomPC-2 Car PC Enclosure can take one Slim CD/DVD drive and a 2.5" HDD drive, it also comes with 2 fans for moisture/heat removal, easy install under the seat or trunk of the car. Dimensions: 210mm (8.3") x 265mm (10") x 66mm (2.2") WxLxH, Weight: 3.7 kg ( 8 Ibs )
    Enclosure Includes:
    -Front panel USB and audio module
    -HDD and CD/DVD drive mounting bracket
    -IDE cable (40 to 44 pin), audio cable, USB cable
    -External power cable
    5. 1GB 240-Pin DDR2 667 Memory
    -Unbuffered 1GB PC4200 667MHz DDR2 Non-ECC CL4 DIMM
    -60 Day Warranty
    6. 120GB SATA 2.5" Notebook Hard Drive
    -Capacity: 120GB
    -Rotational Speed: 5,400 rpm
    -Cache: 8MB
    -Interface: SATA 150
    -Max. External Transfer Rate: 150MB/s
    -Average Seek Time: 12ms
    -Dimension: 3.94 x 2.75 x 0.42 inch (WxDxH)
    7. CD-RW/DVD Slim Combo Drive
    -Type: CD-RW/DVD Slim Combo Bare  Drive
    -Interface: IDE
    -Cache: 2MB
    -Write Speed: 24X CD-R, 24X CD-RW
    -Read Speed: 24X CD-ROM, 8X DVD-ROM
    8. SPEC Research 01028 USB Wired Optical Trackball Keyboard Mouse
    This keyboard removes the repetitive nature of going from keyboard to mouse by combining the two into one device, and while that's been done before, it has never been done as well. The full qwerty keyboard is pretty much as you'd expect it, and the media and web browsing keys are intuitively aligned.
    The optical trackball will be a breeze to use, and as responsive as a high performance sports car. The scroll wheel is equally well placed and just as pleasurable to use. In the unlikely event that a mouse is needed, the keyboard features its own USB port for simple plug'n play operation.
        -Office, Internet and Multimedia Hot Keys
    The SPEC Research 01028 features 23 hot keys with a scroll wheel for efficient management and easy access to the Internet, multimedia and office applications.
        -USB Port
    The SPEC Research 01028 features a USB port for hot-pluggability and easy connection to computers without the need for any software drivers. This design also results in excellent compatibility with current desktop and notebook computers.
        -Integrated Optical Trackball
    The integrated 800 DPI optical trackball provides quick and precise cursor control and negates the need for a mouse.
    9. 800 WATT AMPLIFIER INSTALLATION KIT
    - 18 ft. 10GA Red Power Cable
    - 4 ft. 10GA Black Ground Cable
    - 17 ft. RCA Cable
    - 17 ft. Blue Remote Turn-On Wire
    - 30 ft. 16GA Speaker Wire
    - ATC In-Line Fuse Holder + 30AMP ATC Fuse
    - All Necessary Hardware for Installation
    RAPTOR DISTRIBUTION BLOCK 1-4GA IN 4-8GA OUT10. RAPTOR DISTRIBUTION BLOCK
    - (1) 4GA IN, (4) 8GA OUT
    - Platinum look finish
    - 24K hard gold plated hardware
    - Resistant to corrosion
    - Durable injection molded, black base and clear acrylic cover
    1-4GA IN 4-8GA OUT
    Related Products...
    Mp3Car Custom Car Computer (Preassembled Systems)
    Our Price: $421.57 Please allow up to 3 business days for processing.
    Add
    Our Price: $622.42 Please allow up to 3 business days for processing.
    Add
    Mp3Car Custom Car Computer (5677)
    Our Price: $381.33 Please allow up to 3 business days for processing.
    Add
    Our Price: $1,252.50 Please allow up to 3 business days for processing.
    Add
    MP3Car G4 powered by StreetDeck
    Our Price: $2,199.99 Shipping from April 30th
    Add
     Share your knowledge of this product with other customers... Be the first to write a review.
    Browse for more products in the same category as this item:
    MP3Car
    3 Churchberry Ct.
    Reisterstown, MD 21136
     About Us
     Privacy Policy
     Send Us Feedback
    Company Info | Product Index | Category Index | Help | Terms of Use
    Copyright © 1999 - 2008 MP3Car.com Inc.. All Rights Reserved.
