Home > Vehicle Specific Parts >
  Double Din Bolt in kit with 619 Lilliput toushcreen
  Subaru WRX bolt in kit with toushcreen
Actual kit is brushed aluminum instead of the coated black aluminum pictured.
Our Price: $483.00
Notes: Unavailable
Stock Status: (Out of Stock)
Availability: Discontinued
Product Code: DSH-013
Description Technical Specs
This 619 Lilliput touchscreen monitor in an aluminum housing kits does not require modifications to dashboard and can simply be bolted into place. To install, simply bolt it into place with included parts, connect power and VGA and USB cables and you are ready to go.
Please note that the monitor requires a regulated 12+ input for power and that this item is only a monitor, with no processing capabilities. Also, this kit is only compatible with the 619 Lilliput monitor.
This housing is 100% bolt in compatible with the following models:
Impreza          2002-2006
Forester          2001-2006
Legacy            2005-2006
Outback          2005-2006
Baja                2005-2006
Requires Metra Electronics Kit 99-5087 available at Circuit City
According to metraonline.com, kit will work for the following vehicles:
2004 - 2005 FORD F150
2005 - 2005 FORD FIVE HUNDRED
2005 - 2005 FORD FREESTYLE
2005 - 2005 FORD MUSTANG
2005 - 2005 MERCURY MONTEGO
2005 STI
We have had customers adapt this kit to other vehicles with double DIN openings. Be advised: We are not guaranteeing an exact fit and this may require some modifications on your behalf to make it work. If you think it might fit in your 2DIN opening the Housing Dimensions are: W(7") x H(4.3") x D(7.8") also Here.
Related Products...
Infiniti G35 Ashtray Insert
Our Price: $8.99
Add
Double Din Bolt in Kit with the 7" 629 Lilliput To
Our Price: $499.00
Add
BMW E36 LCD Bezel
Our Price: $175.00
Add
BMW E36 LCD Bezel
Our Price: $149.00
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Monitors and Touchscreens
Monitors and Touchscreens > 7" Touchscreens
Monitors and Touchscreens > In-Dash Touchscreens
Immersion TouchSense PR-1000 Programmable Force Feedback (Haptic) Rotary Encoder with USB Interface $119.99
USB-UIRT (Universal Infrared Receiver/Transmitter) $49.95
Mitch JS USB Audio Selector 4 inputs 1 output - MJS-UAS4S $60.00
CarNetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator $99.95
