Home > Vehicle Computers > Enthusiast Car Computer Systems >
  ToughBox 15 Chenbro Based Intel D510MO Mini ITX System
Alternative Views:
Our Price: $413.00 No Longer Available
Stock Status:(Out of Stock)
Product Code: CCC-211
Operating System:
   Windows Embeded requires a quantity of at least 25 units.
Extra USB Ports*:
   See picture below.
Memory*:
Keyboards:
   One of the nicest and most compact wireless keyboards with a touchpad we've found!
Power Supply Selection:
Prototyping & Systems Integration:
   Please allow up to 3 business days.
Hard Drive*:
Optical Drive:
WiFi:
   Includes antenna & pigtail connector.
Bluetooth:
Centrafuse Software:
   Downloaded and installed by customer.
Description Technical Specs
Our ToughBox 15 is the perfect solution for applications where space and power are at a premium.  Compact, lightweight, powerful, feature packed, this computer is perfect for custom embedded applications, workstations, corporate and government fleet applications, and vehicle applications.  The optional optical bay can house our Teac DV-W28SS -RM3 DVD drive, making a complete solution for in vehicle or workstation use.  Ruggedized Seagate, solid state, or laptop-grade hard drives are available.  Integrated wifi is also available to take advantage of local hot spots.
A conventional 60 watt power supply unit is standard.  Add an optional M3-ATX for mobile use.  Both will be professionally installed by our highly trained technical staff.  Front panel USB and Audio ports are an added feature.  We can even install an extra two USB ports for a total of 8 if additional accessories are required (M3-ATX PSU is recommended for 8 USB ports).
Processor
  • Intel® Atom™ processor D510
Memory
  • Single channel DDR2 with two slots for 800/667 MHz memory support
  • Support for up to 4 GB maximum of system memory
Chipset
  • Intel® NM10 Express Chipset
Audio Intel® High Definition Audio◊ subsystem in the following configuration:
  • Six channel Intel® High Definition Audio
  • Front panel mic/headphone header (2x5)
LAN support Integrated 10/100/1000 network connection
I/O control Legacy I/O:
  • Two PS/2 ports
  • Two serial headers
  • Parallel header
Peripheral interfaces
  • Two Serial ATA ports
  • Seven Hi-Speed USB 2.0 ports (four back panel ports, two ports via header and one USB for Flash /SSD)
Expansion capabilities
  • One PCI
  • One PCI Express* Mini Card
Enclosure Dimensions
  • 9.1" x 3" x 8.6"
Browse for more products in the same category as this item:
Vehicle Computers
