Mobile Systems Integration Specialists
http://www.mp3car.com
View Cart
I
My Account
I
Login
Home
About Us
Help
Contact Us
Our Products
New Products
Open Source Hardware
Vehicle Specific Parts
Mp3Car Forum Made Products
Embedded & Industrial Computers
Custom Car Computer Systems
Monitors and Touchscreens
Computer Hardware
iPad Vehicle Mounts
CarNetix Products (CNX)
Navigation and Software
Engine Diagnostics and OBD
Audio, Radio, and Video
Peripheral Devices
Power
Fusion Brain & Accessories
Mp3Car Swag
Mp3Car Bargain Basement
Information
Mimics
Mp3Car Store Policies & FAQ
Review Your Experience Here
Premium Services & Support
Contact/About Us
Car Computing FAQ
Mp3Car Forums
Mp3Car Homepage
Home
Computer Hardware
Computer Cases
Travla C158 Mini-ITX Case
Our Price:
$114.99
Stock Status:(Out of Stock)
Availability::
Ships in 1 to 2 Business Days
Product Code:
ENC-007
Email me when Back-In-Stock
Description
Technical Specs
The sleek design of the Travla C158 has the small footprint of a mini-itx case with a single PCI expansion slot so you can fit a full size PCI card. In addition to the PCI slot, it has 2 extra USB ports on the side of the case providing you with plenty of expansion slots for various external components. This case is compatible with all VIA mini-itx motherboards as well as most other mini-itx factor motherboards.
Material:
Cold
rolled steel and Extruded Aluminum front panel
Finish:
Black
color paint and aluminum front panel with
anodized
finish
Side
Access:
2x
USB 2.0 and Audio ports, opening for CF reader,
Slim
type Optical Drive
Dimension
(WxHxD):
12"(305mm)
x 2.1"(54mm) x 11"(279mm)
Cooling:
One
4cm low noise fan
Main
Board:
mini-ITX
form factor motherboard
Drive
Bays:
1
slim optical drive and 1 standard (3.5'') HDD
Internal
Power Supply:
Built-in 80W DC power board (Will not be included on builds that have an M1/M2-ATX)
External
AC Adapter:
60
Watts:
Input (100~240 VAC)
Output (12VDC@5A)
Features
If you are going to use the J9F2 motherboard and SATA, slight modification to the PCI riser card is required (cutting away some of the PCB) and a right angled SATA connection is required as well.
Mini-ITX system
with provisions for three serial port connectors on the rear panel
Clean front panel
design with power switch and LEDS only
Fits all VIA mini-ITX
form factor motherboards (memory max height 1.125")
Low noise and lightweight
All black color design
USB 2.0, audio ports, and slim type Media Drive capability
1 PCI slot available
with PCI riser card included
Bonus:
Includes
one set of L-mounting brackets and mounting hardware. Used for wall-or
floor-mounting. Case mounting holes are on each side of the case
Related Products...
VESA Screws for M350 Case
Our Price:
$2.99
Add
New Silver Double Din ABS Frame For Lilliput 669GL
Our Price:
$35.99
Add
New Black Double Din ABS Frame For Lilliput 629 or
Our Price:
$29.99
Add
New Silver Double Din Nano-ITX Carputer Enclosure
Our Price:
$57.95
Add
New Silver Double Din ABS Frame For Lilliput 629 o
Our Price:
$29.99
Add
Browse for more products in the same category as this item:
Computer Hardware
Computer Cases
Computer Hardware
Spare Lilliput Remote Control with Numeric Keypad
$3.99
Slim Line Type CDROM/DVDROM/CDRW Adapter
$7.00
