Home > Computer Hardware > Cables and Adapters > Adapters >
  USB-UIRT (Universal Infrared Receiver/Transmitter)
Our Price: $49.95
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: COM-018
Description Technical Specs Extended Information
The USB-UIRT is a unique IR (infra red) receiver and transmitter.
It connects to your computer through a USB port. It allows you to receive IR signals from regular IR remotes, like your TV remote. Together with a software package like Girder, the USB-UIRT allows your computer to be controlled by a remote in the house. On top of that since the USB-UIRT can send Infra Red signals as well it can control your normal Audio/Video equipment. This could be for example your DVD player, TV, Amplifier or Projector.
Please note that this product is not compatible with all remotes and equipment.  To determine whether it is compatible with your remote or equipment, please consult the Mp3Car Forums.
WHAT IS THE USB-UIRT?
The USB-UIRT is a USB version of the now-notorious UIRT (stands for Universal Infrared Receiver Transmitter). The USB version offers a simple plug-and-play solution without having to deal with some of the hassles of the classic serial-port (RS-232) version.
WHAT DOES THE USB-UIRT DO?
The USB-UIRT, along with Automation Software such as Girder or StreetDeck, allows your PC to both Receive and Transmit infrared signals -- exactly like those used by the collection of remote controls you've acquired for your TV, VCR, Audio System, etc. The USB-UIRT can:
- Receive signals from the remote controls you already have (allowing your PC to perform actions when the 'Play' button is pressed on your VCR remote, for example)
- 'Learn' from remotes you already have and Transmit a duplicate of these signals from your PC (for example, your PC could automatically turn ON your VCR and tune it to channel 3)
- Use codes available from the Web for other remotes (such as the Philips Pronto) to control all of your equipment with Remote (IR) receivers (including special 'discrete' remote codes your brand-name remote doesn't include!). For example, the USB-UIRT could transmit the discrete 'Input 3' code to your TV to directly switch it to input 3, rather than cycling through all of the inputs.
HOW DOES THE USB-UIRT WORK?
The USB-UIRT contains a small micro-controller which is capable of 'listening' for Infrared codes which are transmitted from most remote controls. When IR signals are detected, the USB-UIRT interprets these signals, decodes them, and sends them to your PC via a USB connection. Automation Software such as Girder can be programmed to respond to these codes. In addition, software on the PC can send IR codes to the USB-UIRT to be transmitted. The USB-UIRT's microcontroller will translate these codes to an Infrared stream and transmit them using built-in IR emitters or a connected IR extension.
Related Products...
MSI BToes 2.0 (3X Faster) Bluetooth Network adapte
Our Price: $29.99
Add
MSI BToes 2.0 (3X Faster) Bluetooth Network adapter - Hi-Speed USB
5 FT RCA Patch Cables (set of two)
Sale Price: $0.29
Add
Male to Female Serial Cable 10 foot
Our Price: $4.99
Add
DB9 Male / DB9 Female, 9C, Serial Cable, 1:1, 10 ft, Black (UL)
Intel Wireless WiFi Link 4965AGN - Network adapter
Our Price: $39.99
Add
Intel Wireless WiFi Link 4965AGN - Network adapter - PCI Express Mini Card - 802.11b, 802.11a, 802.11g, 802.11n
5 FT Mini 3.5mm 1/8" Stereo Audio Patch Cable 5ft
Sale Price: $0.29
Add
5 FT Mini 3.5mm 1/8
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Navigation and Software
Peripheral Devices
Peripheral Devices > Input Devices
Mitch JS USB Audio Selector 4 inputs 1 output - MJS-UAS4S $60.00
CarNetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator $99.95
