The USB Serial Adapter provides you with an external serial (DB- 9 male) Plug-n-Play connection for use with computers, notebooks, and hand held computing devices that support USB. The USB Serial Adapter has a standard type A USB plug.
This USB PDA/Serial Adapter high quality serial connections at a data transfer rate of over 500 Kbps. This makes the USB interface transparent to serial peripherals, allowing them to easily interface with USB computers. This eliminates the setup hassle found with traditional serial port connections. This device also supports energy saving suspend and resume operations.
The USB to Serial (DB9) Cable is your fast solution to utilize the peripheral with serial port in an easy-to-use environment such as plug-n-play and hot swap function. This cable provides ideal connections to GPS recivers, interface cards or and other serial device with over 1 Mbps data transfer rate.
