This product allows you to connect two VGA monitors to one VGA source. It is a simple VGA Y-adapter.
The sleek design of the molded connectors makes them easy to grip. The connectors are color coded to match the ports on your personal computer or notebook, ensuring a simple connection. The charcoal gray cable jacket not only matches your case but disappears behind your desk leaving a clean organized look. Constructed with UL tested and certified cable, the cable meets the rigid standards of everyday use. The cable is double-shielded with a dual foil and braid. Copper foil wraps the undermold, while a 360-degree solder-to-connector shell and cable braid create an end-to-end shielding solution for a noise-free connection.
