Home > Computer Hardware > Motherboards >
  VIA C7 2.0GHz Processor Mini-ITX Express Motherboard J7F2WE2G
Our Price: $184.99
Sale Price: $155.00 New Low Price
You Save $29.99!
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: MTB-022
Description Technical Specs Extended Information
  • VIA CN700 Northbridge + VT8237RP Southbridge chipset.
  • Support VIA C7 Nano-BGA processor.
  • Support Front Side Bus 133MHz .
  • Single Channel DDR2 533 Memory DIMM .
  • Support 2 Serial ATA Devices with RAID 0,1 .
  • Support PCI 120-Pin Adapter Conn , With Expansion Daughter-boards .
  • 10 / 100 Ethernet LAN Supported .
  • AC, 97 6 Channel Audio CODEC.
  • VIA VT6307S IEEE1394a Controller .
  • VIA VT1622A TV Encoder .
  • 17 X 17CM Mini-ITX Form Factor.
    Average Customer Review: Based on 2 Reviews. Write a review.
    Related Products...
    D945GSEJT
    Our Price: $119.99
    Add
    D945GSEJT
    Intel BLKD945GCLF2D Mini-ITX Motherboard with Inte
    Our Price: $84.99 New Low Price
    Add
    Intel BLKD945GCLF2D Mini-ITX Motherboard with Integrated Atom™ Processor
    12" ATA (IDE) flexible cable
    Our Price: $2.99
    Add
    Cooler Master EEB-N41SS-01 CPU Fan
    Our Price: $0.99
    Add
    PCMCIA to PCI Adapter from StarTech.com
    Our Price: $24.99
    Add
    StarTech.com CardBus/PCMCIA to PCI Adapter Card - PC card adapter - PCI - Plug-in card
      0 of 0 people found the following review helpful:
    Not too bad... November 10, 2008
    Reviewer: Douglas Williams from Clarks Summit, PA United States
    You would absolutely expect more from a 2.0GHZ board. I have had stable operation for almost a year and successful bios flashes. If you are looking for decent and relatively maintenance free board this good.
    Small CPU footprint and stays cool.
    Beware of small amount of video ram. Can cause slowing of system during video transitions especially if using for carpc. You can do better for the money.
    Was this review helpful to you?
      1 of 1 people found the following review helpful:
    Caution! July 2, 2008
    Reviewer: Josh St John from Colorado Springs, CO United States
    I've had this board board for a while and it never worked right. After some troubleshooting, research and several compatability purchases I found the power and memory compatability requirements are VERY particular and are causing BIOS errors that prevent normal boot operation. Short term fixes (reset button & constantly reconfiguring the BIOS...) allow short term normal operation but usually have to be done more often than not. Do a search on the forums for this board and read all of the issues people have had. They may have worked out some of the voltage issues, since I purchased mine, but Jetway has lost my confidence. I will be buying another board to replace this one very very soon.
    Browse for more products in the same category as this item:
    Computer Hardware > Motherboards > VIA
    Computer Hardware
    Cigarette Lighter Power Adapter for Monitors $3.99
    Mac Mini Power Button Cable Kit $10.00
    Black Momentary Pushbutton Switch 12.5mm $4.99
    Thermometer $7.99
    12" Red SATA II Cable w/ Locking Latch $0.75
    Additional Shipping Costs $360.00
