Join our mailing list!
(Your shopping cart is empty)
  Home > Motherboards >
  VIA Eden 1.2GHz Processor Mini-ITX Express Motherboard J7F2WE1G2E
Our Price: $174.95
Sale Price: $169.99
You Save $4.96!
Notes: Unavailable
Stock Status: (Out of Stock)
Product Code: MTB-019
Description
  • VIA CN700 Northbridge + VT8237RP Southbridge chipset.
  • Support VIA Eden Nano-BGA processor.
  • Support Front Side Bus 133MHz .
  • Single Channel DDR2 533 Memory DIMM .
  • Support 2 Serial ATA Devices with RAID 0,1 .
  • Support PCI 120-Pin Adapter Conn. With Expansion Daughter-boards .
  • 10 / 100 Ethernet LAN Supported .
  • AC, 97 6 Channel Audio CODEC.
  • VIA VT1622A TV Encoder .
  • 17 X 17CM Mini-ITX Form Factor.
    Features
    Form Factor  Mini-ITX Express Motherboard
    CPU  Support VIA Eden 1.2GHz Processor .
     Package type : 400 .
    Memory  1 * 240 -pin DIMM Sockets for unbuffered DDR2 533 SDRAM up to 1 GB.
    Chipset  VIA CN700 + 8237RP chipset .
    Power Management  ACPI S3 Compliant ,supports power saving mode.
    PCI enhanced IDE  4 * Ultra DMA 133 / 100 / 66 IDE Devices Support .
    Serial ATA Interface  2 Serial ATA HDDs with RAID 0.1 Function Support
    VGA Interface  VIA Unichrome Pro Processor .
    Video Memory  Share Memory up to 128MB.
    LVDS Interface  N / A .
    Audio Interface  VIA VT1617A 6-Channel AC 97,  Audio CODEC.
    LAN Interface  VIA VT6103CL 10 / 100 PCI LAN PHY .
    Extended Interface  1 * 32-bit PCI Slot .
     1 * PCI 120-Pin Adapter Connector With Expansion Daughter Boards.
    Internal I/O Port  3 * High Speed USB Connectors @ 480 Mbit / s for 6 USB 2.0 Ports
     CPU / Chassis Fan Connectors / 1 * 26-pin Parallel Connector / 9-Pin COM2 Connector.
     1 * 24 -Pin ATX Power Connector .
     CD / AUX AUDIO IN & SPEAK Out .
    Externall I / O Port
     2 * High Speed USB Connectors @ 480 Mbit / s .
     1 * Serial Port / 1 * D-Sub 15-pin VGA Connector .
     1 * PS / 2 Mouse & 1 * PS/2 Keyboard / 1 * RJ45 Connector / 1 * Audio I / O.
     1 * S-Video Port / 1 * RCA Conn for TV-Out .
    BIOS  Award 4 MB Flash ROM
    Power Requirement  Standard 24 -Pin ATX Power supply .
    Dimension  170mm x 170mm .
    Temperature  Operating within 0~60 centigrade .
     Storage within -20-85 centigrade .
    Related Products...
    PCMCIA to PCI Adapter
    Our Price: $29.99
    Add
    Intel Celeron M 1.46GHz Processor 410 BX80538410SL
    Our Price: $49.99
    Add
    Intel D201GLY2A Little Valley with 1.33 GHz
    Our Price: $74.99
    Add
    Intel D201GLY2A Little Valley with 1.33 GHz Celeron Processor
    Mini-ITX Express Motherboard J9F2
    Our Price: $209.99
    Add
    Intel Pentium M 740 1.73GHz
    Our Price: $49.99
    Add
     Share your knowledge of this product with other customers... Be the first to write a review.
    Browse for more products in the same category as this item:
    Motherboards
    Motherboards > VIA
    MP3Car
    3 Churchberry Ct.
    Reisterstown, MD 21136
     About Us
     Privacy Policy
     Send Us Feedback
    Company Info | Product Index | Category Index | Help | Terms of Use
    Copyright © 1999 - 2008 MP3Car.com Inc.. All Rights Reserved.
    Sell Online with Volusion.
