Home > Computer Hardware > Motherboards >
  VIA Eden @ 1.2GHz Processor Mini-ITX Motherboard Series J7F4K1G2E
Our Price: $179.95
Sale Price: $175.99
You save $3.96!
Notes: Unavailable
Stock Status:(Out of Stock)
Product Code: MTB-023
Description
  • VIA CN700 + 8237RP chipset Technology .
  • Support VIA Eden @ 1.2GHz Nano-BGA processor.
  • Support Front Side Bus 133MHz .
  • Single Channel DDR2 533 Memory DIMM .
  • Support 2 Serial ATA Devices with RAID 0,1 .
  • Dual Gigabit Ethernet LAN Supported .
  • 6 Channel AC, 97 Audio CODEC.
  • 17 X 17CM Mini-ITX Form Factor.
  • Features
    • Form Factor  Mini-ITX Express Motherboard
      CPU Support VIA Eden @ 1.2GHz Processor .
       Package type : 400 .
      Memory 1 * 240 -pin DIMM Sockets for unbuffered DDR2 533 SDRAM up to 1 GB.
      Chipset  VIA CN700 + 8237RP chipset .
      Power Management  ACPI S3 Compliant ,supports power saving mode.
      PCI enhanced IDE  2 * Ultra DMA 133 / 100 / 66 IDE Devices Support .
      Serial ATA Interface  2 Serial ATA HDDs with RAID 0.1 Function Support
      VGA Interface  VIA Unichrome Pro Processor .
      Video Memory  Share Memory up ot 128MB.
      LVDS Interface  N / A .
      Audio Interface  Realtek ALC655 6-Channel AC 97,  Audio CODEC.
      LAN Interface  Dual Realtek RTL8101SC 10 / 100 / 1000 PCI LAN .
      Extended Interface  1 * 32-bit PCI Slot .
      Internal I/O Port  2 * High Speed USB Connectors @ 480 Mbit / s for 4 USB 2.0 Ports
       CPU / Chassis Fan Connectors / 1 * 26-pin Parallel Connector
       1 * 9-Pin COM2 Connector .
       1 * CD / AUX AUDIO IN & SPEAK Out .
      Externall I / O Port
    •  4 * High Speed USB Connectors @ 480 Mbit / s .
       1 * COM Port / 1 * D-Sub 15-pin VGA Connector .
       1 * PS / 2 Mouse & 1 * PS/2 Keyboard .
       1 * RJ45 Connector .
       1 * Audio I / O .
    • BIOS Award 4 MB Flash ROM
      Power Requirement  Standard 24 -Pin ATX Power supply .
      Dimension 170mm x 170mm .
      Temperature Operating within 0~60 centigrade .
       Storage within -20-85 centigrade .
    Browse for more products in the same category as this item:
    Computer Hardware > Motherboards > VIA
    Computer Hardware
