http://www.mp3car.com
Home
My Account
Wishlist
My Cart
0 Items: $0.00
Home
Monitors
Vehicle Monitoring System 9" LCD Screen With 4 CCD Surface Mountable Cameras
Our Price:
$199.95
Sale Price:
$149.95
No Longer Available
You save $50.00!
Stock Status:(Out of Stock)
Product Code:
MON-140
Email me when Back-In-Stock
Description
This vehicle monitoring system is perfect for larger vehicles where multiple cameras are required for safe operation. The 9" LCD monitor can toggle between showing all four cameras at once, two cameras at once on a split screen view, or one camera. This is perfect for larger SUVs, trucks, semi-trailer trucks, motorhomes, and trailers. Four cameras are included and are surface mountable. Each camera has an extra long 16 meter extension cable so cameras can be mounted almost anywhere on your vehicle. Use the included monitor stand to secure it to your dash or use any number of aftermarket mounts. Sturdy build quality. 1 year warranty through mp3Car.
9 inch Super large quad monitor
Built-in Quad Control Box function
Support four cameras at the same time
Single view / double view / quad view selectable
16:9 wide screeen display
NTSC auto switching
Suit for 4 PIN DIN
Suitable for back view / side view cameras
Resolution : 680 * ( RGB ) * 234
Input voltage: DC 12~24V
Monitor Dimensions: 233mm (L) * 160mm (W) * 27mm (H)
Image Pick-up Device : Sharp CCD ( Sony Optional )
Number of Pixels (camera): 510(H) x 492(V)
Horizontal Resolution: 420 TV Lines
IR LEDS : 18 blue LED
Usable Illumination : 1 Lux(F:1.2), 0 Lux with IR LED
Waterproof Resistance : IP 69
IR project distance : 15 meters
Scanning System :525 Lines, 60 Field/sec
Lens : 2.8mm standard
Camera Angle : 120 degree
Video Output :1.0 Vp-p 75 ohm
Operation Temperature : -20℃~+60℃ RH95% Max
Storage Temperature: -30℃~+70℃ RH95% Max
Includes:
1 9" Monitor
4 CCD cameras
1 Remote
1 Stand
4 16M camera extension cables
1 User Manual
1 Monitor Signal Input Connector
1 Monitor Signal Adapter
Related Products...
Lilliput FA1042-NP/C/T 10.4 inch 4:3 Desktop/Wallm
Sale Price: $224.95
Add
Direct Fit Double Din LCD Touch Screen for 2007-20
Our Price:
$299.99
Add
Lilliput 12.1" 16:9 SKD Open Frame Touch Screen VG
Sale Price: $274.95
Add
Lilliput 16.4 Foot 10-pin din cables for Lilliput
Our Price:
$40.00
Add
Direct Fit Double Din LCD Touch Screen for 2008 Bu
Our Price:
$299.99
Add
Browse for more products in the same category as this item:
Monitors
Monitors and Touchscreens
New Products
