Home > Monitors >
  XENARC 700TSH 7" TFT LCD Touch Screen Monitor w/ HDMI, DVI, VGA & AV inputs
Alternative Views:
Our Price: $334.95
Stock Status:In Stock
Product Code: MON-126
Description Technical Specs Extended Information
*NEW* 2011 Model
Xenarc Technologies Corp. is one of the first LCD manufacturers to introduce a 7" LCD screen with HDMI input and Touchscreen. The unit incorporates our latest LED backlight technology for increased brightness and has an ambient light sensor which dims the backlight automatically when required. In addition, Chip Monolithic Ceramic Capacitors are used though out the unit for improved stability and durability especially in extreme temperature conditions.
This popular product incorporates the innovation of our HDMI 7" models along with a 5-wire resistive Touch-Screen panel. Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface. You can connect several 700TSH monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
These monitors come included with an instruction manual, a copper monitor stand, a stylus, an AC adaptor,  a connection cable, a DVI to HDMI adaptor, cigarette lighter car adaptor, and touchscreen drivers for DOS, Windows, Windows Vista, Windows 7, Linux, and Mac OS.
5-Wire Resistive Tochscreen Advantage:
  • 5-wire resistive analog technology is superior to 4-wire, 8-wire and resistive matrix technologies
  • Most durable resistive analog - drift-free operation even when exposed to temperature fluctuation
  • Life span of 35,000,000 touches versus 1,000,000 touches from 4-wire resistive
  • Increased optical clarity equals higher brightness and a sharper display
  • Greater touch point density means better accuracy
  • Faster response time and increased speed
  • No external electronic correction needed
All this means, our great product gets even better while the price stays the same.  While others are constantly cost cutting by switching to cheaper, inferior components, Xenarc is constantly working on bringing you the best products with the most advanced technologies.
Browse for more products in the same category as this item:
Monitors
Monitors and Touchscreens
New Products
Monitors and Touchscreens > 7" Touchscreens
Monitors and Touchscreens > Xenarc
