Home > Monitors and Touchscreens >
  XENARC 706TSA
  XENARC 706TSA
Our Price: $464.00
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: MON-055
Description Technical Specs Extended Information
This monitor utilizes a separate input box which allows a very clean installation.  There is only one cable that needs to be connected to the monitor.  The external input box takes care of power, a DVI input, a VGA input, 2 Composite video inputs, and 3 audio inputs.  And with an optional cable, the monitor can sit 5 Meters away from the input box.  LVDS signaling is utilized between the monitor and the input box to minimize signal degradation.
Utilizing the newest Pixelworks advanced high performance video processor, the 706TSA provides outstanding signal processing, de-interlacing, and scaling.  This is the same chip that is used in high-end TVs and projectors.
Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface.  You can connect several 706TSV monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
Features
  • For In-Car Computing, PC, Server, GPS, and various VGA Use
  • Automotive Grade 650NIT LCD Panel
  • Twin-tube High-Brightness CCFL Backlight
  • 5-wire resistive Touch Screen (USB)
  • Multi-Monitor Touchscreen Support
  • DVI-D Input x 1
  • VGA Input (15 pin D-SUB) x 1 & Video Input x 2
  • Audio Input x 3 / Built-in Speaker
  • Picture In Picture / Split Screen
  • NTSC / PAL Multi-System
  • 16x9 Aspect Ratio
  • High Resolution Display - up to 1600 x 1200
  • Auto detects 800x480 resolution
  • Automatic backlight level adjustment through built-in ambient light sensor
  • Pixelworks High Performance Image and Video Signal Processor
  • AISS - Advanced Image-Scaling and Shaping
  • 16:9 / 4:3 Scaler settings (Auto, Fill All, 1 to 1, Normal, Zoom, Wide)
  • Last Input memory
  • Last Power setting memory
  • IR Remote Control
  • Auto power-on upon signal detection
  • Automatic display adjustment
  • On Screen Display Control
  • Mirror Image Flip
  • Vertical Image Flip
  • Copper Stand: 360° / Height Adjustment
  • Brushed aluminum front bezel
  • VESA 75mm mounting holes
  • 20-Pin and 26-Pin heavy-duty connectors
  • Anti Glare Coating
  • Supports 10V DC ~ 24V DC
  • "E" Mark Certified for Automotive use
Average Customer Review: Based on 1 Reviews. Write a review.
Related Products...
Lilliput 16.4 Foot 10-pin din cables for Lilliput
Our Price: $40.00
Add
Double Din Bolt in Kit with the 7" 629 Lilliput To
Our Price: $499.00
Add
Double Din Bolt in kit
LCD controller ribbon cable 230 mm (15 inches)
Our Price: $2.99
Add
Lilliput 629 Signal Connector
Our Price: $10.00
Add
Extra 619 Lilliput Monitor Casing
Our Price: $20.00
Add
  1 of 1 people found the following review helpful:
I/O box good idea...bad design January 22, 2009
Reviewer: Patrick G from Navarre, FL United States
The input/output box has some major flaws.  The monitor output thumb screw connections do not even match the thumb screws on the cable (one is coarse thread and the other is fine thread) making it difficult to get a solid connection.  The motherboard input connection has spring loaded "clamps to secure the cable to the connector.  It is super loose with no way to tighten it down.  Both of these situations are not good for vehicle operation.  I've already had to return the I/O box for repair after less than 15 hours of use.
Was this review helpful to you?
Browse for more products in the same category as this item:
Monitors and Touchscreens > 7" Touchscreens
Car PC Hacks Book by Damien Stolarz $5.99
P4-12V to P4-12V Cable $2.49 Bulk Pricing Available
3-pin Female-Bare Shielded Wire $1.99
Zonet 802.11g Wireless WIFI USB Adapter ZEW2508 $17.99
Mac Mini Power Button Cable Kit $10.00
Serial ATA Data Cable $3.99
