Home > Monitors and Touchscreens > 10" Touchscreens >
  Xenarc 1040TS 10.4" LCD Monitor with Touch Screen
Our Price: $579.00
Stock Status:(Out of Stock)
Product Code: MON-009
Description Technical Specs Extended Information
Need a portable touchscreen monitor? Don't have enough room for a big bulky 15"? If that's the case, then check out Xenarc Technologies' slim 10.4" TFT LCD monitor with VGA and Touchscreen. This monitor offers you the convenience of a touchscreen at a space-saving size. This monitor supports display resolution up to 800x600 (SVGA). Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the RS-232 port as the interface. The monitor is perfect for Point Of Sales systems with the included stand. The stand can also be removed for use with any VESA mounts, making it perfect for in-car computing purposes.
Features
  • Screen Size: Diagonal 10.4"
  • Display Resolution: 800 x 600 (Max.)
  • Brightness: 180 cd/m²
  • Power Supply: DC 12V/2.5A
  • Power Consumption: 25W
  • Operating Temperature: 32°F ~ 140°F
  • Dimension w/o base (in): 9.9W x 9.0H x 1.6D
  • Weight w/ base (lb): 3.97
  • Resistive Touch Screen (RS-232)
  • On Screen Display Control
  • For PC, Server, GPS, and various VGA Use
  • VGA Input (15 pin D-SUB) x 1
  • 4x3 Aspect Ratio
  • Automatic display adjustment
  • Stand: 90° Vertical / 180° Horizontal Adj.
  • Removable base / stand
  • VESA standard mounting holes
  • Supports 12V DC
  • FCC, CE, UL
Browse for more products in the same category as this item:
Xenarc 706TSA 7" TFT LCD Touchscreen Monitor w/ DVI & VGA & AV inputs $409.95
Xenarc 705TSV 7" TFT LCD Touchscreen Monitor w/ VGA & AV inputs $259.95
XENARC 700TSU 7" TFT LCD Touch Screen Monitor w/ USB Display Interface & AV inputs $349.00
NEW 2010 Model XENARC 1020TSV - 10.2" VGA LCD Touchscreen Monitor $458.95
VoomPC-2 CarPC Enclosure $89.95
