Please note: CA residents will be charged an additional 8.75% tax rate on this item after your order is finalized.
Need a portable touchscreen monitor? Don't have enough room for a big bulky 15"? If that's the case, then take a look at Xenarc Technologies 12.1" TFT LCD monitor with VGA and Touchscreen. This monitor offers you the convenience of a touchscreen at a space-saving size. This monitor supports display resolution up to 800x600 (SVGA). Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface. The monitor is perfect for Point Of Sales systems with the included stand. The stand can also be removed for use with any VESA mounts making it perfect for in-car computing or home automation purposes. This monitor comes included with an instruction manual, a removable stand, an AC adaptor, a connection cable, and touchscreen drivers for DOS, Windows, Linux, and Mac OS.
- Model #: 1200TS
- Screen Size: Diagonal 12.1"
- Physical Resolution: 800 (H) x 600 (V) SVGA
- Supported Resolution: 640 x 480 ~ 800 x 600
- Dot Resolution: 2400 x 600 = 1,440,000 (dots)
- LCD Brightness: 220 cd/m²
- Power Supply: DC 12V
- Power Consumption: 35W
- Operating Temperature: 32°F ~
140°F
- Dimension w/o base (in): 12.2W x 10.7H x 1.9D
- Dimension w/ base (in): 12.2W x 12.3H x 6.4D
- Weight w/ base (lb): 11
- 12 Month Warranty
- 8-Wire Resistive Touch Screen (USB interface)
- On Screen Display Control
- For PC, Server, GPS, and various VGA Use
- VGA Input (15 pin D-SUB) x 1
- 4x3 Aspect Ratio
- Automatic display adjustment
- Removable base / stand
- Supports 12V DC
- ROHS, FCC, CE, UL
