Home > Monitors and Touchscreens > In-Dash Touchscreens >
  Xenarc 700IDT 7" In-Dash LCD Touch Screen Monitor
Xenarc 700IDT In Dash 7 inch Touch Screen VGA Monitor
Our Price: $399.95
Stock Status:In Stock
Product Code: MON-017
Description Technical Specs Extended Information
XENARC 700IDT™
7" IN-DASH LCD Monitor w/ VGA & Touch Screen
This popular product incorporates the innovation of all of Xenarc's VGA 7" models along with a 5-wire resistive Touch-Screen panel.  Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface.  You can connect several 700IDT monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
This monitor comes included with an instruction manual, connection cables, and touchscreen drivers for DOS, Windows, Windows Vista, Linux, and MAC OS.
**Note - All of our inventory is 2008 "B" serial inventory.  Our current "B" version is an improvement on the older "a" revision.
The B version has a 500 nit panel and new features such as mirror image flip and vertical image flip.
Features
    • For In-Car Computing, PC, Server, GPS, and various VGA Use
    • 1-DIN In-Dash, heavy duty construction
    • Spring loaded, automated mechanical flip-out design (Non-Motorized)
    • Left and Right swivel
    • No vertical tilt capability
    • 5-wire resistive Touch Screen (USB)
    • Multi-Monitor Touchscreen Support
    • VGA Input x 1 & Video Input x 2
    • NTSC / PAL Multi-System
    • 16x9 Aspect Ratio
    • High Resolution Display - up to 1600 x 1200
    • Upgraded High-Brightness CCFL
    • Adjustable backlight level for night-time use
    • Pixelworks High Performance Image and Video Signal Processor
    • AISS - Advanced Image-Scaling and Shaping
    • Auto power-on upon signal detection
    • Automatic display adjustment
    • On Screen Display Control
    • 20-Pin heavy-duty connector
    • Anti Glare Coating
    • Supports 11V DC ~ 24V DC
    • "E" Mark Certified for Automotive use
Browse for more products in the same category as this item:
Monitors and Touchscreens > Xenarc
Xenarc 706TSA 7" TFT LCD Touchscreen Monitor w/ DVI & VGA & AV inputs $409.95
Xenarc 705TSV 7" TFT LCD Touchscreen Monitor w/ VGA & AV inputs $259.95
XENARC 700TSU 7" TFT LCD Touch Screen Monitor w/ USB Display Interface & AV inputs $349.00
NEW 2010 Model XENARC 1020TSV - 10.2" VGA LCD Touchscreen Monitor $458.95
